Just a User Guest
PWD relationship of duty value |
Posted: Sun May 04, 2008 11:13 am |
I was under the impresion that the period and duty were directly related. For example if I set the following:
int16 period = 99; //
setup_power_pwm(PWM_FREE_RUN,1,0,period,0,1,0);
then to get 100% duty cycle I would run:
int16 duty_cycle2 = 100; //100%
set_power_pwm0_duty(duty_cycle2);
but that seems to not be the case. If fact with the code below, 4x the period seems to be the 100% duty cycle. Could someone explain the relationship between the two if there is one?
#include<18f4331.h>
#device adc=10
#fuses INTRC_IO, NOWDT, NOPROTECT, NOBROWNOUT, PUT, NOLVP
#use delay(clock=8000000) //8Mhz
int16 duty_cycle1, duty_cycle2, duty_cycle3, duty_cycle4;
setup_oscillator(OSC_8MHZ);
setup_power_pwm_pins(PWM_COMPLEMENTARY ,PWM_COMPLEMENTARY, PWM_OFF, PWM_OFF);
duty_cycle1 = 800; //???%
duty_cycle3 = 25; //25%
while (true) {
set_power_pwm0_duty(duty_cycle1);
set_power_pwm0_duty(duty_cycle3);
} //while
}//main() |
Posted: Sun May 04, 2008 2:34 pm |
Quote: | If fact with the code below, 4x the period seems to be the 100% duty
one?
The period is based on units of Fosc/4. But the duty cycle is based on
units of Fosc. To see this, change the main loop in your program to this:
while (true)
set_power_pwm0_duty(1);
With a duty cycle of 1, you'll see a 125 ns pulse on your oscilloscope.
If change it to 2, you'll see a 250 ns pulse. It increments in units of
125 ns. That's the period of the 8 MHz oscillator.
But you can only change the period in units of 500 ns. This means the
setting for your duty cycle has 4x higher resolution than the setting
for the period. That's just the way Microchip designed it. They felt
that users wanted high resolution on the duty cycle setting. |
Posted: Sun May 04, 2008 2:37 pm |
They are directly related.
However the PWM, internally uses the master 'instruction' clock, for the period, and the original input clock for the 'width' (*4). This is why you can have period values up to 255 (256), but width values up to 1023. The actual PWM period control register, only accesses the 8 bit counter, that directly relates to the period value. There are though two 'extra' bits, that provide access to two bits corresponding to the higher speed counter.
CCS, 'changes mode', according to the value you use to control the PWM period. If you use an 8bit value (int8), then it only accesses the main PWM control register. If you use a 16bit value, then it automatically takes the top eight bits of this, and puts these into the main register, and the low two bits into the extra control.
Now, if you use a cast like this:
set_power_pwm0_duty((int8)duty_cycle1);
The PWM, will behave as you expect.
With your constants, the compiler automatically switches to using an int16 type, if the constant is over 255, forcing access to the extra control bits.
Just a User Guest
Thanks |
Posted: Sun May 04, 2008 3:16 pm |
Thanks guys.. |
