multiple compilation units ?
Dimmu
PostPosted: Sun May 04, 2008 4:33 am     Reply with quote
Does anybody know if the 'multiple compilation units' is working with the last version of CCS ?
I'm currently working with 4.053 and this feature seems to be unable to manage the types others than the default ones. In the following example, I receives the error code 112 : function used but not defined.
// main.c
#include "project.h"
#include "func.h"
void main (void) {
   A_STR_T VAR_A;
   FUNC_A ( VAR_A );
   FUNC_B ( &VAR_A );
// project.h
#include <16F877A.h>
#use delay(clock=20mhz)
#use rs232(BAUD=9600, UART1, STREAM=PC)
// func.h
typedef struct {int A;} A_STR_T;
// typedef int A_STR_T;
void FUNC_A ( A_STR_T value );
void FUNC_B ( A_STR_T * value );
// func.c
#include <project.h>
#include "func.h"
void FUNC_A ( A_STR_T value ) {
   printf ( "A" );
void FUNC_B ( A_STR_T * value ) {
   printf ( "B" );
If however I replace the definition of "A_STR_T" by the one that is commented in func.h, then the code is compiled Shocked
Ken Johnson
PostPosted: Mon May 05, 2008 12:51 pm     Reply with quote
I've not yet had the opportunity to get into this, but expect to soon, as new projects commence. So, I recently asked CCS about multiple compilation units. Their response:
"The compiler does support multiple compilation units and it should work just like you would expect.
Today we can not link to Microchips object files however we expect to be able to do so soon."
Let's hope . . .
Ken
Dimmu
PostPosted: Tue May 06, 2008 3:28 am     Reply with quote
Thank you for the feedback,
I hope it's gonna work as they say in new version of the compiler.
Dimmu
