pic16f877a + ds1307 dont work
PostPosted: Sat May 03, 2008 8:07 pm     Reply with quote
I am working with a pic 16f877a and a ds1307 with a library that you post in this web, my simulation in Proteus is working perfect, but in the protoboard, i have a trouble, doesn't work, could you help me ?
I think that i have the correct crystal, a battery of 3.5 volts in pin 3, pullups resistor of 2K and ...the best try that i make, the time run 20 real seconds were equivalent in the circuit to 8 seconds.
Thats my trouble i shut down and turn on again and it runs 1 second in near to 40 seconds.
i check and check again, like 40000 times and i don t see any mistake, and in this forum in found that the crystal could be the trouble, it says 32.768.
crystal_lattice
slow seconds
PostPosted: Sun May 04, 2008 12:59 am     Reply with quote
Your crystal load capacitance could be too big, this will cause it to run slow or not at all, they should be around 7pf if i'm not mistaken.
elizabeth ann
PostPosted: Sun May 04, 2008 1:21 am     Reply with quote
in our project we used a TCXO from Maxim which is the DS32kHz. perhaps you are only using an ordinary crystal oscillator which may not be stable at all times. the DS32kHz is temperature-compensated so that the output frequency is very much stable.
try it. Wink good luck!
jotasmall
PostPosted: Sun May 11, 2008 4:14 pm     Reply with quote
thanks for your help, but i am really surprise, i put a capacitor of 0.1u between vcc and pin2 with the negative side in vcc and it works, but yet doesn´t run in real time.
i suscribe to this forum, because i was reading and i found very useful information...
my mind is broken!!
crystal_lattice
PostPosted: Mon May 12, 2008 3:14 am     Reply with quote
what do you mean by
cluelesskiller
PostPosted: Mon May 12, 2008 5:55 am     Reply with quote
Have you read the datasheet for the DS1307, or are you just randomly connecting it from bits and pieces of information you've read on the internet?
