Problems with fuses
xsnake
Problems with fuses
PostPosted: Fri May 02, 2008 5:37 am     Reply with quote
I've got an issue regarding fuses. Simple created new project using pcwhd 4.068 (i guess this issue was in earlier versions), then i've changed NOWDT to WDT and NOPUT to PUT, but there nothing has changed in lst file (and inside flashed pic configuration words as well). Source:
#include <18F6722.h>
#device ICD=TRUE
#device adc=8
#use delay(clock=16000000)
#FUSES WDT //No Watch Dog Timer
#FUSES HS //High speed Osc (> 4mhz)
#FUSES BORV25 //Brownout reset at 2.5V
#FUSES PUT //No Power Up Timer
#FUSES NOLVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES LPT1OSC //Timer1 configured for low-power operation
#FUSES XINST //Extended set extension and Indexed Addressing mode enabled
#FUSES BBSIZ1K //1K words Boot Block size
End of generated lst file:
Configuration Fuses:
Word 1: C200 HS IESO FCMEN
Word 2: 0E19 NOBROWNOUT WDT128 NOWDT BORV25 NOPUT
Word 3: 85F3 CCP2C1 LPT1OSC MCLR
Word 4: 0000 NOSTVREN DEBUG NOLVP NOXINST BBSIZ1K RESERVED
Word 5: C0FF NOPROTECT NOCPD NOCPB
Word 6: E0FF NOWRT NOWRTD NOWRTC NOWRTB
Word 7: 40FF NOEBTRB NOEBTR
Data from hex file:
:02000004 0030 CA
:0E000000 00C2 190E F385 0000 FFC0 FFE0 FF40 B4
so @300000 we have exactly same fuses:
C200 0E19 85F3 0080 C0FF E0FF 40FF - 7 config words, they were read by ICD interface program (why 0080 instead of 0000 in hex - the second question).
But as fact NOPUT and NOBROWNOUT and NOWDT were compiled instead of having them PUT BROWNOUT WDT... Shocked
can anybody help me with solving this issue?
Thanks in advance!
PS: - i've got it - these fuses were marked as Force fuses for ICD debugging usage (when compiled with ICD=TRUE). When there is no ICD=TRUE, all fuses become ok.
PostPosted: Fri May 02, 2008 7:31 am     Reply with quote
You already figured out it has to do with the ICD=TRUE setting.
Set this to NOXINST. The wizard is a bit optimistic here as the compiler does not yet support the Extended Instructions and enabling these might cause erratic program behaviour.
xsnake
PostPosted: Fri May 02, 2008 8:42 am     Reply with quote
yep, thanks
