18F4620 and AN3
Mark Weir
18F4620 and AN3
PostPosted: Tue Apr 29, 2008 6:50 pm     Reply with quote
Hi ALl,
I have been attempting to complete a design using AN0,1,2 and 3.
I have the following setup:
   setup_adc_ports(AN0_TO_AN3|VSS_VDD);//AN0
   setup_adc(ADC_CLOCK_DIV_32);
   setup_comparator (NC_NC_NC_NC);
   setup_vref (FALSE);
I am getting results from AN3 that look like the pin is set as a reference for the comparator. With nothing connected to the pin I read 4.8 volts on the AtoD.
Perhaps I have overlooked something in the setup or maybe someone has had a similar problem. I am using version 4.071 of the compiler.
Cheers
Mark
Life is too short to avoid asking questions
Matro
PostPosted: Wed Apr 30, 2008 9:15 am     Reply with quote
The setup_adc() should indicates an acquisition time.
For instance, for an acquisition time of 2.4µs :
   setup_adc(ADC_CLOCK_DIV_32|ADC_TAD_MUL_12);
Matro
PostPosted: Wed Apr 30, 2008 9:34 am     Reply with quote
RA3, doesn't connect to the comparator Vref. RA2 does. If RA3 is high, check that the TRIS is set to 1 on this pin, and look carefully at your external wiring. If it is RA2, then check that the CVROE bit, is being cleared, by the setup Vref, and not just the Vref being disabled. So, just read it:
#byte CVRCON=0xFB5
#bit CVROE=CVRCON.6
if (CVROE==1) printf("This is the problem");
Or something similar, after disabling the Vref.
