how to use PWM and CCP_CAPTURE_FE ?
ruijing2
PostPosted: Wed Apr 30, 2008 4:04 am     Reply with quote
hi can u help me?
i use ccs c and PIC18F452.
i want to use PWM and CCP_CAPTURE_FE.
Try it but when i on PWM and CCP_CARTURE_FE TOGETHER as ccp1 and ccp2. The PWM(ccp2) did something to the CCP_CARTURE_FE(ccp1) interrupt.
#elif defined(__PCH__)
#include <18F452.h>
#device ICD=true
#fuses HS,NOWDT,NOLVP,WDT128,NOPUT,NOBROWNOUT,NOPROTECT,NOWRTD,CPD
#use rs232(parity=N,BITS=8,xmit=PIN_C6,rcv=PIN_C7)  // Jumpers: 8 to 11, 7 to 12
int32 en=0;
int32 countstore=0,countstore2=0;
unsigned int32 count=0,duty=128;
int32 ans=0,ans3=0,ans2=0;
int32 in=0,count2=0;
#INT_TIMER1
void time1()
  // for(;;)
   count++;
#INT_CCP1
void hahah()
//      if(count2>=1 && count2 <17 )
      countstore2=CCP_1;
      countstore=count;
      count=0;
  //else if(count2==0)
    //    en=CCP_1;
    //    count2++;
    //    count=0;
ans3=((countstore*65536)+countstore2)-en;
 //       printf("en=%lu \r\n ",en);
  //      printf("countstore2=%lu \r\n ",countstore2);
  //       printf("countstore=%lu \r\n ",countstore);
   //      printf("count2=%lu \r\n ",count2);
   //      printf("ans=%lu \r\n ",ans);
         countstore=0;
         in=0;
         if(en!=countstore2)
        en=countstore2;
       // count2++;
       // count=0;
     if(count2!=0)
     ans2+=ans3;
     count2++;
      if(count2==17)
         ans=ans2/(count2-1);
  //       printf("count2=%lu \r\n ",count2-1);
  //       countstore=0;
         count2=0;
  //       countstore2=0;
         in=0;
         ans2=0;
    //     countstore2=CCP_1;
    //     countstore=count;
   set_uart_speed(9600);
   setup_ccp1(CCP_CAPTURE_FE);
   setup_ccp2(CCP_PWM);
   setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1);
   setup_timer_2 ( T2_DIV_BY_1, 255, 1);
   enable_interrupts(INT_CCP1);
 for(;;)
   if(in==0)
      if(ans>10000001 && duty >0)
         duty--;
      }else if(ans<9999999 && duty <128)
         duty++;
    in=1;
    set_pwm2_duty(10L);
Matro
PostPosted: Wed Apr 30, 2008 4:16 am     Reply with quote
Please post a small clean compilable code that demonstrates the problem and try to provide a deeper explanation of the issue you are encountering.
Matro
ruijing2
PostPosted: Wed Apr 30, 2008 4:22 am     Reply with quote
#INT_TIMER1
void time1()
#INT_CCP1
void hahah()
for(;;)
set_pwm2_duty(10L);
ruijing2
re:
PostPosted: Wed Apr 30, 2008 4:34 am     Reply with quote
it keep interrupt the ccp1 as it will interrupt at 1s only
Matro
PostPosted: Wed Apr 30, 2008 5:16 am     Reply with quote
I definitely don't understand what is the "problem".
What is your hardware?
What are you trying to do?
What did you expect?
What do you really obtain?
Matro
ruijing2
PostPosted: Wed Apr 30, 2008 5:47 am     Reply with quote
i want to use EXTERNAL 1pps to read 10M count from EXTERNAL 10MHz clock. And to control the PWM.
