lovlylion
Problem with writing in program flash mem |
Posted: Mon Apr 28, 2008 4:02 pm |
HI all
i tried to write in flash program memory using CCS on pic16f887 , the compilation process give me succesful but running it not doing any thing...its my code :
#include <16F887.h>
void main(){
int i=0x1000
for(;i<=0x1fff;i++) {
value=0x0006;
write_program_memory(i, value, 2);
Posted: Mon Apr 28, 2008 4:53 pm |
Where are your #fuses and #use delay() statements ? Where are your variable declarations ? How are you checking if the program memory
has been written correctly ?
Post a complete test program with all of the items listed above.
Also post your compiler version.
Is this test being done on a hardware board, or are you doing it with
a simulator in MPLAB or Proteus ? |
Posted: Tue Apr 29, 2008 4:51 am |
i don't use anything need delay,
i use mplab v8.0.2
i have pickit2 so i tested with it and read mem after execution of this program
its the complete code:
#include <16F887.h>
// 16F887.h for fuse option constants.
#FUSES INTRC,NOWDT,NOPUT,NOMCLR,NOPROTECT,NOCPD,NOBROWNOUT,NOIESO,NOFCMEN,NOLVP
void main(){
int i=0x1000,value=0x0006;
Matro Guest
Posted: Tue Apr 29, 2008 5:18 am |
Declaration of variables shall not be "int" but "unsigned int16".
Matro. |
Matro Guest
Posted: Tue Apr 29, 2008 5:22 am |
Moreover data shall be transmitted through a pointer.
#include <16F887.h>
void main(){
unsigned int16 i,value;
value=0x0006;
for(i=0x1000;i<=0x1fff;i++) {
write_program_memory(i, &value, 2);
Matro |
Posted: Tue Apr 29, 2008 11:42 am |
thank u matro;
but iam sorry to tell u that it still not working , but compilation process succed :( |
Matro Guest
Posted: Wed Apr 30, 2008 1:55 am |
Anonymous wrote: | thank u matro;
Be aware that this code will take about 0x1000 * 5ms = 20s to execute.
Moreover, you set the NOMCLR fuse so your device can't be programmed through ICSP. I don't how you program it, but if you use ICSP programming it will surely result in bugs.
If this is the problem, the following code should work:
#include <16F887.h>
#FUSES INTRC,NOWDT,NOPUT,MCLR,NOPROTECT,NOCPD,NOBROWNOUT,NOIESO,NOFCMEN,NOLVP
void main(){
value=0x0006;
Matro |
Blob
Joined: 02 Jan 2006 Posts: 75 Location: Neeroeteren, Limburg, Belgium
Posted: Wed Apr 30, 2008 6:06 am |
hello,
you declare int16.
it is 4 bytes right?
no, not right, as matro mentions in next reply a byte is 8 bits
and an int16 is then 2 bytes
then write_program_memory(adress, dataptr, count)
adress being the adress 16 bit
dataptr pointer to data
count bytes to write => int16 = 4 bytes => count should be 4
nit should be 2
Best Regards
Matro Guest
Posted: Wed Apr 30, 2008 6:12 am |
Blob wrote: | hello,
you declare int16.
Best Regards |
When working with PIC (like most of CPUs), a byte is 8-bit long.
So an int16 is 2 bytes.
"count" shall be 2 as mentioned.
Matro |
Blob
Posted: Wed Apr 30, 2008 6:18 am |
Wow, thanks Matro that will help me in my own project!!!
i will change my post to avoid misunderstandings...
thanks |
