micro65
write_eeprom...error |
Posted: Mon Apr 28, 2008 11:42 am |
Hi to all,
this is a subroutine for writing in eeprom:
boolean Write_int_eep(int *buffprt, int n_byte, int address)
byte b;
disable_interrupts(GLOBAL);
for(;n_byte>0;n_byte--,buffprt++,address++)
b=*buffprt;
if(read_eeprom(address)!=b)
write_eeprom(address,b);
if(read_eeprom(address)!=b) //errore in scrittura
return false;
return true;
why it does not work?
the read_eeprom works perfectly but the write_eeprom does not write anything.
The chip is 18f252.
If I insert, for example, this code..... write_eeprom(0x10, 0x55)....at the beginning of the code (in main) the byte 0x55 is written correctly
Best regards. |
Posted: Mon Apr 28, 2008 11:45 am |
Post a test program that calls this function. Show all #include, #fuses,
and #use statements. Show all variable declarations. The program
must be compilable with no errors. Also show the printf statement
that displays the result.
Post your compiler version. |
micro65
Posted: Mon Apr 28, 2008 12:20 pm |
thanks for your answer
#include <DS1307.c>
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include <18F252.h>
#device ICD=TRUE
#device adc=8
#FUSES HS //High speed Osc (> 4mhz)
#FUSES PROTECT //Code protected from reads
#FUSES NOOSCSEN //Oscillator switching is disabled, main oscillator is source
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES DEBUG //Debug mode for use with ICD
#FUSES NOEBTRB //Boot block not protected from table read
//DEFINIZIONI
#define SINCRO '%' //carattere sincronismo
#define SPACE ' '
#define CR 0x0D //carriage return
#define LF 0x0A //line feed
#define TRUE 1
#define FALSE 0
#define MAX_COLONNE 48 //massime colonne di led
#define RX_BUFFER_SIZE 65 //30
#define DECIMALE 0x40 //primo led dal basso acceso
#define SEPARATORE 0 //colonna che separa due cifre
#define VAL_TIMEOUT 5 //circa 5 secondi
#define CLK_VIS PIN_A0 //Clock per acquisizione dato
#define STRB_VIS PIN_A1 //Strobe per caricamento dati
#define EN_VIS PIN_A2 //Enable pin
#define RES_VIS PIN_A3 //Reset pin
#define DIR_485 PIN_A5//stabilisce in 485 se in Tx o Rx (in 422 sempre in RX)
//corrispondenza locazioni in eeprom
#define BAUD_RX 0 //In eeprom interna locazione 0 mem. Baud rate
/* value 0 = 2400
value 1 = 4800
value 2 = 9600
value 3 = 19200 */
#define DECIMALI 2
#define SI_ORA 4
#define UM 6
#define NOSOVRAC 8
#define SCRITTA 0x20
//VARIABILI
static unsigned long cTimeOut; //timeout per TMR0
static unsigned long cTimeOut1; //timeout per TMR1
static unsigned char cRxBuffer[RX_BUFFER_SIZE]; //buffer seriale
static unsigned char cVisBuffer[MAX_COLONNE]; //buffer visualizzazione
static unsigned char cStr1[5]={"SET1"};//per programmazione
static unsigned char cStr2[5]={"SET2"};//per programmazione
static unsigned char cStr3[5]={"SET3"};//per programmazione
static unsigned char cStr4[5]={"SET4"};//per programmazione
static unsigned char cStr5[5]={"SET5"};//per programmazione
static unsigned int *cRxBufferprt; //puntatore
static unsigned int *cBuffGenprt; //puntatore Buffer gnerico
static unsigned char cCount; //conteggio generico
static unsigned char cDecimal; //numero decimali
static unsigned char cReceive; //Byte in ricezione
static unsigned char cGen; //per uso generale
static unsigned char cRiferimenti;
static unsigned char c_UM[2];
#ROM 0x00F00000 = {0x01, 0x03, 0x01, "oz", 0x00} //inizializzazione eeprom (baud rate 4800, decimali = 0....)
#ROM 0x00F00020 = {"******************************"}
I think it is sufficient
Thanks |
Posted: Mon Apr 28, 2008 12:25 pm |
That's not what I wanted. I want to see a test program that calls
the Write_int_eep() function. I don't need to see all those #define
statements and static variables that are not related to the problem.
Only put code that is related to the problem. Also, your posted code
is not compilable.
Here's an example of a test program.
http://www.ccsinfo.com/forum/viewtopic.php?t=32722&start=3 |
micro65
Posted: Mon Apr 28, 2008 12:36 pm |
this code calls Write_int_eep() function:
separate void GestProg()
if((cRxBuffer[1]=='S')&&(cRxBuffer[2]=='E')&&(cRxBuffer[3]=='T')&&(*(cRxBufferprt-1)==CR))
switch(cRxBuffer[4])
case('1'):
if(Write_int_eep(&cRxBuffer[5],60,SCRITTA))
printf("OK scritta\r");
printf("KO scritta\r");
cRxBuffer[0]=NULL;
cRxBuffer[1]=NULL;
*(--cRxBufferprt)=NULL;
case('2'):
if(Write_int_eep(&cRxBuffer[5],2,UM))
printf("OK unita' misura\r");
printf("KO unita' misura\r");
cRxBuffer[0]=NULL;
cRxBuffer[1]=NULL;
bye |
Posted: Mon Apr 28, 2008 12:38 pm |
I didn't get a test program or the compiler version, so I'm giving up. |
micro65
Posted: Mon Apr 28, 2008 1:02 pm |
the compiler version is 4.065 |
Posted: Mon Apr 28, 2008 3:17 pm |
I looked into your problem too and agree with PCM Programmer: Post a test program!
A small program that shows your problem. The program must be complete, i.e. including all required #fuses, include files, etc. so we can copy / paste the code into our compiler. Make the program small, not larger than what fits on a single screen and remove everything that is not required.
We know you will have to put some effort in creating such a test program but we ask this for some special reasons:
- From your description it looks like the problem is in how you call the function.
- When creating the test program it is very likely you will find the problem yourself.
- A complete test program saves us a lot of time. We do help the people here in our spare time and only pick the fun questions. The easier you make it for us the quicker and better help you will get. |
micro65
Posted: Tue Apr 29, 2008 12:08 pm |
ok, sorry but I did not understand.
However I found the problem.
The problem is only in Debug mode con icd-u (version firmware 1.39),
normally everything works perfectly.
Indeed in debug mode the following code works only in part
case('6'):
cRxBuffer[0]=NULL;
cRxBuffer[1]=NULL;
cRxBuffer[0x2c]=NULL;
cRxBuffer[0x2f]=NULL;
cRxBuffer[0x34]=NULL;
cRxBuffer[0x37]=NULL;
cRxBuffer[0x3A]=NULL;
day = atoi(&cRxBuffer[0x2A]);
cRxBuffer[0]=NULL;
cRxBuffer[1]=NULL;
are reset to zero
remain unchanged.
Why?
Thanks |
