Large array problem
sohailkhanonline
View user's profile Send private message Visit poster's website Yahoo Messenger MSN Messenger
Large array problem
PostPosted: Mon Apr 28, 2008 3:05 am     Reply with quote
Hi following is my hardware info
#include <18F4620.h>
#fuses HS, NOWDT, NOLVP, NODEBUG
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7,bits=8)
the application is connected to ethernet and i want to recieve this string in array
HTTP/1.1 200 OK
Server: Microsoft-IIS/5.1
Date: Mon, 28 Apr 2008 08:50:23 GMT
X-Powered-By: ASP.NET
X-AspNet-Version: 2.0.50727
Set-Cookie: ASP.NET_SessionId=pzvtzcrlvwydngr2ga1jsymm; path=/; HttpOnly
Cache-Control: private, max-age=0
Content-Type: text/xml; charset=utf-8
Content-Length: 357
<?xml version="1.0" encoding="utf-8"?><soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><soap:Body><GetTimeResponse xmlns="http://tempuri.org/"><GetTimeResult>Please Call Again</GetTimeResult></GetTimeResponse></soap:Body></soap:Envelope>
If i declare array of sufficient length like
800 or 900 or even 1200 following is the part of data that is saved in array
Following is the code for declaring this array
char keydata[900];
int indextodata;
char c;
TCPSocket socket;
      while (TCPGet(socket, &c))
        keydata[indextodata]=c;
        indextodata++;
        printf("%c",c);
How can i get the whole data in one string
sohail khan
sohailkhanonline
SOLVED
PostPosted: Mon Apr 28, 2008 5:50 am     Reply with quote
when i declare the index variable as
static unsigned int16 index;
the index was having an overflow.
everything worked fine..
sohail khan
Wayne_
PostPosted: Mon Apr 28, 2008 6:20 am     Reply with quote
That is because an int is only 8 bit.
int = UInt8 (0 to 255)
