RS232 Dosn't work on PIC18F4520 Development Kit
PostPosted: Thu Apr 24, 2008 2:04 pm     Reply with quote
Can't seem to get the Rs232 port to work correctly. I have the CCS PIC18F4520 Development Kit (prototype board).
The following code will compile and execute, but I don't get the results I expect. Using Hyperminal (9600-N-1-8) with the supplied CCS RS232 cable, I can run the program and the GREEN LED turns on and waits for a kbhit. So far so good. Then I tap any key on the heyboard and the YELLOW LED turns on. Great ! But the key that I tap is not the ASCII data I see in the debugger ( variable char c). I get garbage. Also... nothing on the Hyperterminal screen (I guess since the data is garbage and non printable).
I have also tried using printf putc, etc. No luck.
It's gotta be something simple. Any suggestions ?
Marc
Here's the C code:
#include "main.h"
#define GREEN_LED PIN_A5
#define YELLOW_LED PIN_B4
#define RED_LED PIN_B5
char c;
c = 'K';
output_low(GREEN_LED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
if(kbhit(L1) )
output_low(YELLOW_LED);
c = getc(L1);
fputc('D',L1);
// HERE'S My Inlcude File
#include <18F4520.h>
#device ICD=TRUE
#device adc=8
#FUSES LP //Low power osc < 200 khz
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES LVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
#use delay(clock=20000000,RESTART_WDT)
#use rs232(stream=L1,baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
PostPosted: Thu Apr 24, 2008 2:16 pm     Reply with quote
Change this to the HS fuse. Notice the comment.
You want to run at 20 MHz. You can't use the LP fuse to do that.
The HS ("High Speed") oscillator fuse is required.
#FUSES LVP
Change this to NOLVP. Do that in all your programs.
