gnz Guest
12hv615 |
Posted: Tue Apr 22, 2008 10:14 am |
Hi everybody,
I have problem with 12HV615. I use picc 4.071 and write a program for the 12hv615. But i could not load it to the microchip. I have both icd-u40 and icd2. When i try to connect mplab say target device is not connected and u40 says could not detect the chip. Is there any difference of connections to debugger or any other thing?
Thank for your replies. |
Matro Guest
Posted: Tue Apr 22, 2008 11:07 am |
If the PIC isn't powered by the board, you have to activate "target is powered by ICD" in MPLAB and to plug the external DC block to ICD.
Matro. |
gnz Guest
Posted: Wed Apr 23, 2008 4:14 am |
Thanks Matro, but the board is powered by 5 volt. And i try another hv615 in case of the hv615 are broken. |
Matro Guest
Posted: Wed Apr 23, 2008 5:38 am |
So check your hardware. Nothing should hold MCLR, RB6 or RB7 at a low or high level.
During ICSP, these 3 pins shall be high impedance.
Matro. |
Posted: Wed Apr 23, 2008 5:44 am |
Thanks Matro, the problem is resolved. I have uninstalled and install new version of Mplab and then problem is resolved. But CCS U40 still could not recognize the target. |
Matro Guest
Posted: Wed Apr 23, 2008 5:46 am |
Maybe this programmer doesn't support this device. Check in the list of supported devices. ;-)
Matro. |
