kein
Sampling frequency with timer0 interrupts problem |
Posted: Thu Apr 17, 2008 2:35 am |
Hello Guys?
I'm sampling a signal from adxl330 accelerometer at 1000HZ using timer0 to interrupt every 1ms (0.001S) and then print out the values to hyperterminal. The formula I used to achieve reload time is:
Rt =65536 - tm*Fosc/(4*Fscal)
where tm =time =0.001
Fosc =Clock frequency =20MHZ
Fscal =prescaler =256
Rt= 65536 - (0.001*20*10^6)/(4*256)
= 65536- 20
= 65516
so I used set_timer0(65516) as shown in the code. The problem is the values I'm getting are wrong. Can anyone tell me what the problem is?
Code: | #include <16F877A.h>
#device *=16
#device adc=10
#FUSES NOWDT, HS, NOPUT, NOPROTECT, NODEBUG, NOBROWNOUT, NOLVP, NOCPD, WRT_50%
#byte PORTB = 0x06 // PortB lives in File 6 (data bus)
#byte PORTC = 0x07 // PortC lives in File 7 (address bus A12 to A8, RX, TX & R/W)
#byte PORTD = 0x08 // PortD lives in File 8 (address bus A0 to A7)
#byte PORTE = 0x09 // PortE lives in File 9 (used for DIP switches)
#include <stdio.h>
#include <2416.C>
#include <stdlib.h>
#BIT ADFM = 0xFC0.7
#use fast_io(B) // Fast access to PortB (don't fiddle with TRISB)
#use fast_io(C) // Fast access to PortB (don't fiddle with TRISB)
#use fast_io(D) // Fast access to PortD (don't fiddle with TRISD)
#use fast_io(E) // Fast access to PortE (don't fiddle with TRISE)
unsigned int16 dc;
int16 data;
int1 flag;
#int_TIMER0
void TIMER0_isr(void)
set_timer0(65516); //reload for the next 1 ms (65536 - (tick*20*e6)/(4*256)) where t =0.001 second
dc++;
//read_adc(ADC_START_ONLY); //only starts the conversion read_adc(); start adc
read_adc();
if(dc > 2048)
flag = 1;
dc = 0;
#int_AD
void AD_isr(void )
int16 tmp;
//ADXL330ACCELCalibrateXYZ();
set_adc_channel(0); // select the required channel
tmp = read_adc();
//tmp=read_adc(ADC_READ_ONLY); //reads the result of the last conversion and store it in value
data = (tmp - 512L);
printf("%.2f,\t%0Ld \r\n",(dc*0.01) ,data);
if(data >= -2 || data <= 2)
data =0L;
//#define LCD_TYPE 1
#include <LCD4X20.C>
void ADLX330ACCELBlinkLED(unsigned char on, unsigned char off, unsigned char tm);
unsigned int16 result;
int16 res =0L;
data = 0L;
result= 0L;
set_tris_b(0x17); // TRISB = 00010111; RB4,RB2,RB1 and RB0 TTL Inputs
port_b_pullups(FALSE); // Don't use internal pull up resistors
setup_adc_ports(AN0_AN1_AN2_AN4_AN5_VSS_VREF);
setup_adc(ADC_CLOCK_DIV_64);
setup_timer_0( RTCC_DIV_256 ); //Timer0 enabled with a 245 prescaler
ADFM = 1;
lcd_gotoxy(1,1);// Type some characters and backspace over them.AccelBuff
lcd_putc(" X Y Z");
enable_interrupts(INT_AD);
dc = 0L;
flag = 0;
// TODO: USER CODE!!
if (flag==1)
flag = 0;
ADLX330ACCELBlinkLED(9, 4, 12);
int i;
for(i = 0; i < tm; i++ )
output_low(PIN_B5);
delay_ms(on);
output_high(PIN_B5);
delay_ms(off);
RLScott
Re: Sampling frequency with timer0 interrupts problem |
Posted: Thu Apr 17, 2008 5:42 am |
If you are getting an interrupt every 1 ms., then inside that interrupt rountine you are calling printf, which sends stuff at 9600 baud to hyperterminal, then that will take up much more than 1 ms., so you obviously can't be getting an interrupt every 1 ms. At 9600 baud it takes 1 ms. just to send a single character. To really see what is going on, take the printf (and anything else that consumes a lot of time) out of the ISR and put it in the main program. Of course you can't get a printout of every single reading no matter how you do it. But for purposes of checking that the readings are correct, it would be good enough to print whatever reading is current at the time you happen to look.
So after you fix those things, then tell us what is being printed out and what you think should be printed out.
Robert Scott
Real-Time Specialties |
Matro Guest
Posted: Thu Apr 17, 2008 8:22 am |
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256);
//code continue
set_timer0(60533); //will overflow after 1ms
Matro.[/code] |
kein
Thanks guys |
Posted: Thu Apr 17, 2008 8:34 am |
Hi Matro,
How did you get to 60533?
I thought at 20MHZ clock and @ 1ms, the math will be as follows.
Code: | ReloadTime = (65536 - 20*10^6*0.001/(4*256))
= (65536 - 19.5)
= 65536 - 20
= 65516 |
or did you use prescaler of 1?
kind regards,
S.Kein |
Douglas Kennedy
Posted: Thu Apr 17, 2008 8:58 am |
A good rule is to never put a printf in an isr unless you are debugging and are willing to accept that the printf will mess up horribly any speed or timing . |
Matro Guest
Re: Thanks guys |
Posted: Thu Apr 17, 2008 9:18 am |
kein wrote: | Hi Matro,
= (65536 - 19.5)
= 65536 - 20
= 65516 |
kind regards,
S.Kein |
I look at CCS Wizard that indicates an overflow of 13.1ms for a PIC16F877 with 20MHz clock and prescaler of 256.
And just calculate (65536 * 12.1 / 13.1) to obtain a 1ms overflow.
Matro. |
Matro Guest
Posted: Thu Apr 17, 2008 9:35 am |
The correct calculation is :
65536 - 65536 * time * Fosc / (4 * 256 * prescaler)
In your case :
65536 - 65536 * 0.001 * 20000000 / (4 * 256 * 256) = 60536
Matro. |
kein
Thank you |
Posted: Sat Apr 19, 2008 10:31 am |
Thanks matro
Kind regards |
kein
No no no it' does not work at all |
Posted: Tue Apr 22, 2008 4:10 am |
Guys I've removed printf() from the interrupt sub routine and now the signal I'm getting is really worst.
Signal from the signal generator is 0-5v and offsetted at 2.5V.
Its frequency is 4Hz and my sampling frequency Fs is 100Hz.
my crystal frequency is 20MHz.
I've modified a code by PCM programmer. Why can't I get a nice sign wave output into the comm?
I've tried to increase the baud rate with no improvement!!
#device *=16
#device adc=10
#use rs232(baud=19200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
// DEFINES
// With a 20 MHz oscillator, a RTCC pre-scaler of 256, and a RTCC
// preload of 196, we get an rtcc interrupt rate of 100.16 Hz (Approx.
// every 10 ms).
// This will be our "tick" clock that we use for various event timers.
#define RTCC_PRELOAD (256 - 196)
// Multiply the following values x 10 ms to get the delay times,
// since each timer tick is 10 ms.
#define BUTTONS_TIMER_TICKS 2 // 20 ms
#define IRDA_TIMER_TICKS 10 // 100 ms
#define LED_TIMER_TICKS 50 // 500 ms
#define UART_TIMER_TICKS 100 // 1000 ms
#include <stdio.h>
#include <2416.C>
#include <stdlib.h>
#BIT ADFM = 0xFC0.7
#byte timer0low = 0xfd6
// GLOBALS
char gc_buttons_timer;
char gc_IRDA_timer;
char gc_LED_timer;
char gc_uart_timer;
unsigned int16 dc;
int16 data;
int1 flag;
void AD_isr(void );
void TIMER0_isr(void);
void DispData();
void BlinkLed();
int16 res =0L;
data = 0L;
result= 0L;
flag = 0;
prescaler
setup_timer_0(RTCC_INTERNAL|RTCC_8_BIT|RTCC_DIV_256);
set_adc_channel(1); // select the required channel //
delay_us(10);
ADFM = 1;
set_timer0(RTCC_PRELOAD);
dc = 0L;
flag = 0;
// This is the main loop. You put your "tasks" here.
DispData();
BlinkLed();
int i;
output_low(PIN_B5);
delay_ms(on);
delay_ms(off);
void DispData()
if(gc_buttons_timer)
return;
gc_buttons_timer = BUTTONS_TIMER_TICKS;
void BlinkLed()
if(gc_LED_timer)
return;
gc_LED_timer = LED_TIMER_TICKS;
// Put your LED blinking state machine here.
ADLX330ACCELBlinkLED(50, 50, 3);
// The rtcc interrupt occurs when the rtcc rolls over from FF to 00.
// I have programmed it to interrupt at a 100 Hz rate.
// RTCC interrupt rate = Fosc / (4 * rtcc pre-scaler * rtcc pre-load)
// = 20 MHz / (4 * 256 * 196)
// = 100.16 Hz
// This gives us a timer tick approx. every 10 ms (9.98 ms actually).
#int_TIMER0
// Reload the RTCC, so it will keep overflowing every 10 ms.
//set_rtcc(RTCC_PRELOAD);
timer0low = timer0low + RTCC_PRELOAD;
dc++;
// Decrement any timers that are running.
gc_buttons_timer--;
if(gc_IRDA_timer)
gc_IRDA_timer--;
if(gc_LED_timer)
gc_LED_timer--;
if(gc_uart_timer)
gc_uart_timer--;
#int_AD
void AD_isr(void )
int16 tmp;
RLScott
Re: No no no it' does not work at all |
Posted: Tue Apr 22, 2008 4:35 am |
kein wrote: | Guys I've removed printf() from the interrupt sub routine and now the signal I'm getting is really worst....I've tried to increase the baud rate with no improvement!! |
What you do mean the signals are worst? What did you expect to get? What are you really getting? Show us the data.
Robert Scott
kein
alias signal |
Posted: Tue Apr 22, 2008 4:39 am |
signal is affected very much by aliasing.I was expecting a nice sign wave singal coz my sampling frequecny is 25X my signal frequency
kind regards |
kein
I'm running nuts! |
Posted: Tue Apr 22, 2008 5:34 am |
Is there a function that can be placed inside an interrupt subroutine that will send the data to the PC other then printf() function which is known to take too much time?
This thing is driving me nut! |
Matro Guest
Re: I'm running nuts! |
Posted: Tue Apr 22, 2008 5:58 am |
kein wrote: | Is there a function that can be placed inside an interrupt subroutine that will send the data to the PC other then printf() function which is known to take too much time?
That will ever be better to use putchar() and to send just one character with the value you want to scan.
Matro. |
Posted: Tue Apr 22, 2008 7:32 am |
First of all, do a search here about 'INT_AD', and see why you want to avoid this. I have posted quite a bit about this. Use it by all means, but _only_ if you are triggering the ADC, using the CCP. Otherwise all you are doing, is wasting processor time.
You would be better, in the code you have posted, to _read_ the ADC, when you enter the timer interrupt, then re-trigger it. This way the sampling will happen between each timer interrupt, _without_ the overhead associated with another interrupt.
On sending data, it is not inherently printf, but the actual time taken to _send_ characters. If you even just putc, a single character, if the output hardware buffer is full, you will have to wait for an entire character time. Printf, makes this 'worse', because it'll almost always end up sending multiple characters, and you then add the overhead of working out what to send as well... Do a search here on 'bputc'. Buffered serial _transmit_ routines, using a software buffer. In your case, you can (again) save the overhead associated with another interrupt for this, by using your timer 'tick'. So:
#bit TXIF=0xC.4
#define TXBUFF_SIZE (32) //set to suit your worst case
int8 TXBuff[TXBUFF_SIZE];
int8 in=0,out=0,count=0; //use separate counter for speed
#define incr(x) if(++x==TXBUFF_SIZE)x=0
#byte TXREG=0x19
void bputc(char chr) {
TXBuff[in] = chr;
incr(in);
DISABLE_INTERRUPTS(INT_TIMER0);
if (++count==TXBUFF_SIZE) {
--count;
incr(out);
//throw away oldest character if overflow
ENABLE_INTERRUPTS(INT_TIMER0);
// = 100.16 Hz
#int_TIMER0
//Get rid of the INT_AD
data=(signed int16)(read_adc(ADC_READ_ONLY)) - 512L;
//read last ADC
read_adc(ADC_START_ONLY); //start the next conversion
dc++;
gc_buttons_timer--;
if(gc_IRDA_timer)
gc_IRDA_timer--;
if(gc_LED_timer)
gc_LED_timer--;
if(gc_uart_timer)
gc_uart_timer--;
//Now handle serial transmission of buffered character
if (count!=0) {
//A character is waiting
if (TXIF) {
//The output buffer has space
TXREG=TXBuff[out];
incr(out);
count--;
TXIF=0;
//Now 'key' is that if a character is waiting in the output buffer
//it checks to see if the hardware can take a character. If it can,
//just one character is sent.
//The 'send' overhead is then very small indeed in the timer interrupt.
Now, with this, you can send data inside an interrupt (though you will still need to be careful if you send very much....). Just use:
printf(bputc,"what you want to send",vals);
This sends a maximum of 100 characters per second, with minimal delays. Note it also shows how to read the ADC, without using the 'INT_AD', and without wasting time waiting for a reading.
One other comment. You should not read 'data' in a printf, as you are doing. The problem is that printf takes quite a time, and the interrupt could update after half the value is read. Read data like:
int16 local_data;
disable_interrupts(GLOBAL);
local_data=data;
and printf this 'local' copy. This may be part of the reason for erratic results.
kein
Thanks Ttelmah |
Posted: Wed Apr 23, 2008 2:55 am |
Hi Ttelmah,
It same behaviour as printf() far much and very slow. If I used inside interrupt subroutine, nothing is print out of the terminal. Secondly if I used inside main(0, performance is really poor!
I don't know what I'm doing wrong?
#device *=16
#device adc=10
// DEFINES
// With a 4 MHz oscillator, a RTCC pre-scaler of 256, and a RTCC
// preload of 39, we get an rtcc interrupt rate of 100.16 Hz (Approx.
// every 10 ms).
#define BUTTONS_TIMER_TICKS 4 // 40 ms
#include <stdio.h>
#include <24256.C>
#include <stdlib.h>
#bit TXIF=0xC.4
#BIT ADFM = 0xFC0.7
#byte TXREG=0x19
void AD_isr(void );
void DispData();
void BlinkLed();
void bputc(char chr);
void DispDataAdxl330();
int16 res =0L;
data = 0L;
result= 0L;
flag = 0;
prescaler
delay_us(10);
ADFM = 1;
//enable_interrupts(INT_AD);
dc = 0L;
flag = 0;
int16 local_data = 0L, cnt =0;
DispData();
BlinkLed();
local_data=data;
cnt = dc;
printf(bputc,"%0Ld,%0Ld\n\r", cnt, local_data);
int i;
output_low(PIN_B5);
delay_ms(on);
delay_ms(off);
// If the button debounce delay has not counted down yet,
// then just return. If it has counted down to 0,
// then reload the timer and execute the rest of
// this function.
// The timer tick is set for a 10 ms period, so let's
// say a suitable debounce time would be 20 ms or more.
// So we'll set CHECK_BUTTONS_TICKS = 2.
// So this function will execute approximately every 2 ticks,
// or 20 ms.
void DispData()
return;
/*disable_interrupts(GLOBAL);
local_data=data;
cnt = dc;
printf(bputc,"%0Ld,%0Ld\n\r",dc,local_data); */
void BlinkLed()
if(gc_LED_timer)
return;
TXBuff[in] = chr;
incr(in);
--count;
incr(out);
// = 100.16 Hz
#int_TIMER0
data=(signed int16)(read_adc(ADC_READ_ONLY) - 0x0266); //read last ADC
dc++;
gc_buttons_timer--;
if(gc_IRDA_timer)
gc_IRDA_timer--;
if(gc_LED_timer)
gc_LED_timer--;
if(gc_uart_timer)
gc_uart_timer--;
if (count!=0) {
if (TXIF) {
TXREG=TXBuff[out];
incr(out);
count--;
TXIF=0;
#int_AD
void AD_isr(void )
//write_ext_eeprom(dc,(int8)tmp);
/* disable_interrupts(GLOBAL);
local_data=data;
