I have switches connected to RA0, RA1, RA2, RA4, and RA5. I would like to use the internal pullups on these pins but cannot seem to get it to function properly. Here is the code:
void main(void) {
int32 milliseconds, time_delay;
setup_oscillator(OSC_8MHZ); // Setup internal oscillator to 8MHz
set_tris_a(0b00111111); // Setup TRIS register for port A
setup_adc_ports(sAN6); // Dial pot is on analog channel 6
setup_adc(ADC_CLOCK_INTERNAL); // Use normal clock
set_adc_channel(6); // Set ADC MUX to channel 6
setup_timer_0(RTCC_INTERNAL | RTCC_DIV_16); // Set up the millisecond timer
setup_timer_1(T1_INTERNAL | T1_DIV_BY_8);
port_a_pullups(0b00110100); // Enable pullup resistors on port A
enable_interrupts(INT_RTCC);
while(TRUE) {
if(!input(INT_TMR)) output_high(RELAY); // Turn on relay
if(input(ON_TMR)) output_low(RELAY); // Turn off relay
switch(0x10) {
case SEC_1: time_delay=SEC1_MS;
case SEC_10: time_delay=SEC10_MS;
case MIN_1: time_delay=MIN1_MS;
case MIN_10: time_delay=MIN10_MS;
It appears after examining the code deeper that the ANSEL registers need to be manually written to to allow the operation of the port_a_pullups() for this part.
