| Pointer to const array? |
Posted: Mon Apr 21, 2008 4:41 am |
Hi
What is wrong here. The code is just an ex. from a bigger context.
Is I handling the pointer corect?
The problm is I cant accecc the const array?
| Code: | //located in prom
const int8 c_data[6]={0xFF,0x41,0x61,0x11,0x91,0xd1};
//test function
void t2(void){
int8* data;
int16 i;
data=&c_data;
for(i=0;i<6;i++) write_data(*data++);
But if I use this function - no problem!
| Code: | void t3{
int16 i;
for(i=0;i<6;i++) write_data(c_data[i]);
Matro Guest
Posted: Mon Apr 21, 2008 5:02 am |
Below an excerpt of CCS help about constant data tables :
| Quote: |
BYTE CONST TABLE [10]= {9,8,7,6,5,4,3,2,1,0};
and to access the table use:
x = TABLE [i];
OR
x = TABLE [5];
BUT NOT
ptr = &TABLE [i];
In this case, a pointer to the table cannot be constructed.
I think all is here...
Matro |
Posted: Mon Apr 21, 2008 5:13 am |
Hi
Yes I have looked at this ex. but, is it impossible???
/F |
Posted: Mon Apr 21, 2008 5:22 am |
Actually, you can now (only working in the last few compiler versions), have pointers to constant arrays, _but_ you have to use the 'ROM' construct, rather than the 'const' construct. The difference is that the latter includes a header 'program', to access the data. The former just places the data, and has a slightly more complex access arrangement. This allows the code to be able to calculate 'where' the actual data is, and pointers to be used.
So:
//located in prom
int8 ROM c_data[6]={0xFF,0x41,0x61,0x11,0x91,0xd1};
//test function
void t2(void){
int8* data;
int16 i;
data=&c_data;
for(i=0;i<6;i++)
Should work.
The manual has not 'caught up' with this, but it is in the 'readme.txt' that comes with the compiler.
Posted: Mon Apr 21, 2008 6:40 am |
Hi
Thanks, but I cant get it to work using pointers?
I just use the old way... |
Posted: Mon Apr 21, 2008 7:02 am |
What I posted, compiled, and ran, on 4.070, using putc, instead of write_data, and gave the right output.
Posted: Mon Apr 21, 2008 8:00 am |
Hi.
Thanks for the information:-) |
