It is only allowed global variables?
pattousai
PostPosted: Sun Apr 20, 2008 9:04 am     Reply with quote
Hi everyone, i have the 4.057 compiler and i'm using his IDE.
So... everytime i put a local variable (inside the main()) i get the error:
A numeric expression must appear here
To fix that i have to put the variable at global scope. It is true that i can't have any local variables?
once i used the version 3.xxx and there i remember of using local variables.
thanks for the attention and sorry for the bad english
pattousai
PostPosted: Sun Apr 20, 2008 9:25 am     Reply with quote
hi everyone...
another thing that is going wrong is that i'm trying to print a int16 (as decimal unsigned int, i.e. using %d) over the serial and i'm getting the error:
Print format type is invalid ::
The error dissapear when i put the hexadecimal format (%X)...
so... i can't display a int16 as decima??
PostPosted: Sun Apr 20, 2008 9:42 am     Reply with quote
There is no way anyone can help you without seeing your code.
Please post the section of code where you are having problems and the variable declarations.
PostPosted: Sun Apr 20, 2008 9:49 am     Reply with quote
To print an int16, the format specifier is %ld. It always was. The new compiler though _warns_ you that the format is wrong. Some older ones didn't.
Local variables behave just as they have always done. Any variable declared inside a function is local. You need to post an example, so we can see what is wrong.
KU5D
PostPosted: Sun Apr 20, 2008 1:23 pm     Reply with quote
For the 'numeric value' error, look for a mismatch in braces ( for every { you need a } ), misplaced semicolons, other typos above where the error occurs.
It's hard to answer the question without seeing the code...
Confidence is the feeling you have right before you fully understand the situation...
future
PostPosted: Sun Apr 20, 2008 7:46 pm     Reply with quote
You must put all declarations at the beginning of the function before everything else.
pattousai
PostPosted: Tue Apr 22, 2008 8:59 pm     Reply with quote
thanks everybody for the help...
the display error was only the lack of the L...
and about the variables... well, i noted that the compiler not permitted if the definition is inside the while(true) (i guess that makes sense), is just put inside of a condition test (if) that it is allowed
again, thanks very much
