Too many inputs = too much current?
temp2290
PostPosted: Sun Apr 20, 2008 1:38 pm     Reply with quote
I have a PIC16F877A that I have working code for, but when I expand the code to use more inputs (nothing is really different as far as the computation goes), the PIC does nothing. I have 20 inputs going into the pic and 8 outputs. The inputs are all on ports A, B, and C. My inputs are all regular switches that work on the other code.
I'm wondering if too much current may be flowing into the PIC with all the inputs?
PostPosted: Sun Apr 20, 2008 2:22 pm     Reply with quote
The PIC input pins draw almost no input current. It's more likely that
you forgot to specify the NOLVP fuse, and when you set pin B3 to a high
level, the PIC locked up. You need the following fuse:
#fuses NOLVP
temp2290
PostPosted: Sun Apr 20, 2008 2:34 pm     Reply with quote
Alright, thanks, so it's not a current problem. I should have known that.
As for the NOLVP, I have that fuse set.
I'm not sure of the problem, I'll have to try some other stuff out.
