PICoHolic
[Resolved] USB & Win Vista error code 10 |
Posted: Thu Apr 17, 2008 11:12 am |
Just a quick question, I'm using PIC18F87J50 on CCS v:4.066 and Microchip USB bulk driver. On XP it works perfect. On Vista, the PC fails to recognize the device attached (error in driver even if I'm using the latest drivers provided by microchip - framework 2.1). The question: the CCS usb code, is it compatible with win VISTA? do i need updates?
joven
Joined: 30 Jan 2007 Posts: 56 Location: Viana do Castelo - Portugal
PICoHolic
Posted: Fri Apr 18, 2008 11:49 am |
Thanks joven,
But that's not what i'm looking for. I need to stick to the CCS usb API & Microchip bulk usb driver.
AntonioB
Posted: Fri Apr 18, 2008 12:21 pm |
Ok, i don't understand at all what are you trying to do, but if you want yo use USB from Vista it has changed, the all drivers and so don't work now, you need to get new ones, so that should be your problem, i guess you can find out more looking for WinUSB driver, hope it help you. |
Tomy
PICoHolic
Posted: Fri Apr 18, 2008 11:55 pm |
Yes i've tried it but no luck..
I even got the newest driver (framework 2.1) and still. no luck :( |
Douglas Kennedy
Posted: Sat Apr 19, 2008 12:12 am |
Maybe Vista isn't a reliable solution. Being an early adopter of Vista puts you in a Starship going were no one has gone before. USB on a Microsoft platform has its own degree of random issues. Now if you enjoy the blue screen of death and unpredictable crashes then you won't be disappointed. Waiting several years and letting others test Vista could be the smart way to go. |
PICoHolic
Posted: Sat Apr 19, 2008 12:57 am |
I like it
But i have no other choice |
PICoHolic
Posted: Fri Apr 25, 2008 11:28 am |
No one is facing such problem !?!??!
Now i have tha latest compiler version 4.071 and still no luck under Vista.
I'm using the MCP usb bulk driver (framework 2.1)
PICoHolic
Posted: Fri Jun 27, 2008 2:29 am |
After doing some investigations and testings, i can affirm that the problem is in the CCS USB firmware API.
I have tried the Microchip latest Vista USB bulk driver on their firmware and t works perfect under Vista.
Now what? |
Ken Johnson
Joined: 23 Mar 2006 Posts: 197 Location: Lewisburg, WV
Posted: Fri Jun 27, 2008 6:49 am |
Contact CCS
Ken |
PICoHolic
Posted: Mon Mar 09, 2009 3:43 am |
I had to fix these values to 64 and it worked:
#define USB_EP1_TX_SIZE 64 //size to allocate for the tx endpoint 1 buffer
#define USB_EP1_RX_SIZE 64 //size to allocate for the rx endpoint 1 buffer
nuwavedc
Posted: Mon Mar 09, 2009 7:02 am |
PICoHolic
Do have enumeration data I can view, I am troubleshooting a similar problem with CCS CDC. _________________ Thanks,
NuWaveDC |
PICoHolic
Posted: Mon Mar 09, 2009 7:14 am |
here's my usb_desc.h
//// usb_desc.h ////
#IFNDEF __USB_DESCRIPTORS__
#DEFINE __USB_DESCRIPTORS__
#include <usb.h>
/// start config descriptor
/// right now we only support one configuration descriptor.
/// the config, interface, class, and endpoint goes into this array.
#DEFINE USB_TOTAL_CONFIG_LEN 32 //config+interface+class+endpoint
//configuration descriptor
char const USB_CONFIG_DESC[] = {
//config_descriptor for config index 1
USB_DESC_CONFIG_LEN, //length of descriptor size
USB_DESC_CONFIG_TYPE, //constant CONFIGURATION (0x02)
USB_TOTAL_CONFIG_LEN,0, //size of all data returned for this config
1, //number of interfaces this device supports
0x01, //identifier for this configuration. (IF we had more than one configurations)
0x00, //index of string descriptor for this configuration
0xC0, //bit 6=1 if self powered, bit 5=1 if supports remote wakeup (we don't), bits 0-4 reserved and bit7=1
0x32, //maximum bus power required (maximum milliamperes/2) (0x32 = 100mA)
//interface descriptor 0 alt 0
USB_DESC_INTERFACE_LEN, //length of descriptor
USB_DESC_INTERFACE_TYPE, //constant INTERFACE (0x04)
0x00, //number defining this interface (IF we had more than one interface)
0x00, //alternate setting
2, //number of endpoints, not counting endpoint 0.
0xFF, //class code, FF = vendor defined
0xFF, //subclass code, FF = vendor
0xFF, //protocol code, FF = vendor
0x00, //index of string descriptor for interface
//endpoint descriptor
USB_DESC_ENDPOINT_LEN, //length of descriptor
USB_DESC_ENDPOINT_TYPE, //constant ENDPOINT (0x05)
0x81, //endpoint number and direction (0x81 = EP1 IN)
0x02, //transfer type supported (0 is control, 1 is iso, 2 is bulk, 3 is interrupt)
USB_EP1_TX_SIZE & 0xFF,USB_EP1_TX_SIZE >> 8, //maximum packet size supported
0x01, //polling interval in ms. (for interrupt transfers ONLY)
0x01, //endpoint number and direction (0x01 = EP1 OUT)
USB_EP1_RX_SIZE & 0xFF,USB_EP1_RX_SIZE >> 8, //maximum packet size supported
//****** BEGIN CONFIG DESCRIPTOR LOOKUP TABLES ********
//since we can't make pointers to constants in certain pic16s, this is an offset table to find
// a specific descriptor in the above table.
//NOTE: DO TO A LIMITATION OF THE CCS CODE, ALL HID INTERFACES MUST START AT 0 AND BE SEQUENTIAL
// FOR EXAMPLE, IF YOU HAVE 2 HID INTERFACES THEY MUST BE INTERFACE 0 AND INTERFACE 1
#define USB_NUM_HID_INTERFACES 0
//the maximum number of interfaces seen on any config
//for example, if config 1 has 1 interface and config 2 has 2 interfaces you must define this as 2
#define USB_MAX_NUM_INTERFACES 1
//define how many interfaces there are per config. [0] is the first config, etc.
const char USB_NUM_INTERFACES[USB_NUM_CONFIGURATIONS]={1};
#if (sizeof(USB_CONFIG_DESC) != USB_TOTAL_CONFIG_LEN)
#error USB_TOTAL_CONFIG_LEN not defined correctly
/// start device descriptors
//device descriptor
char const USB_DEVICE_DESC[] ={
USB_DESC_DEVICE_LEN, //the length of this report
0x01, //constant DEVICE (0x01)
0x10,0x01, //usb version in bcd
0x00, //class code (if 0, interface defines class. FF is vendor defined)
0x00, //subclass code
0x00, //protocol code
USB_MAX_EP0_PACKET_LENGTH, //max packet size for endpoint 0. (SLOW SPEED SPECIFIES 8)
0xD8,0x04, //vendor id (0x04D8 is Microchip)
0x20,0x00, //product id 0020
0x00,0x01, //device release number
0x01, //index of string description of manufacturer. therefore we point to string_1 array (see below)
0x02, //index of string descriptor of the product
0x00, //index of string descriptor of serial number
USB_NUM_CONFIGURATIONS //number of possible configurations
/// start string descriptors
/// String 0 is a special language string, and must be defined. People in U.S.A. can leave this alone.
/// You must define the length else get_next_string_character() will not see the string
/// Current code only supports 10 strings (0 thru 9)
//the offset of the starting location of each string.
//offset[0] is the start of string 0, offset[1] is the start of string 1, etc.
const char USB_STRING_DESC_OFFSET[]={0,4,24};
#define USB_STRING_DESC_COUNT sizeof(USB_STRING_DESC_OFFSET)
char const USB_STRING_DESC[]={
//string 0
4, //length of string index
USB_DESC_STRING_TYPE, //descriptor type 0x03 (STRING)
0x09,0x04, //Microsoft Defined for US-English
//string 1
20, //length of string index
'M',0,
'U',0,
'L',0,
'T',0,
'I',0,
'L',0,
'A',0,
'N',0,
'E',0,
//string 2
36, //length of string index
'S',0,
'e',0,
'r',0,
'i',0,
'a',0,
'l',0,
' ',0,
'C',0,
'o',0,
'n',0,
't',0,
'r',0
'o',0
'l',0
'l',0
'e',0
'r',0
#ENDIF
I didn't change anything else... |
