How best to poll UART bit
SherpaDoug
PostPosted: Fri Apr 18, 2008 9:04 am     Reply with quote
I need to find when the hardware UART transmit buffer is empty so I can shut off the RS485 driver. For odd reasons I can't simply use the enable option of the #use rs232 statement. From the PIC18F2528 datasheet it seems I need to monitor TXSTA bit 1. But I can't find and address for the TXSTA register in either the CCS 18F2585.h file or the datasheet.
If I could fine the address I could write a line like this:
#BIT TXSTA_TRMT = 0x????.1 //Transmit buffer empty
Where should I look for the address? Is there a better way?
Matro
PostPosted: Fri Apr 18, 2008 9:17 am     Reply with quote
TXSTA is at address 0xFAC
TRMT is #BIT 0xFAC.1
You can also poll the TXIF bit (in progress transmission flag) is it is better for your application. But polling TRMT is definitely the way to know if the transmit buffer is empty or not.
SFR mapping is (as Microchip used to) in section "Memory organization" of the datasheet (SFR mapping starts at page 70).
Matro
SherpaDoug
PostPosted: Fri Apr 18, 2008 9:48 am     Reply with quote
Thanks, I knew it had to be somewhere in the @#$%^ 484 page datasheet!
It looks like PIR1_TXIF (0xF9F.4) is set when the final data bit is clocked out. You wouldn't happen to know if it is at the beginning or end of the Stop bit? I need to generate a 5ms break character (long start bit) on the RS485 line to synchronize data collection.
ThomasC
PostPosted: Fri Apr 18, 2008 3:54 pm     Reply with quote
This thread may further help you. It worked for me!
http://www.ccsinfo.com/forum/viewtopic.php?t=22649&highlight=txif
