| newbe programing help |
Posted: Fri Apr 11, 2008 1:52 pm |
Hi all,
Here a little explanation of what I want. I have a 16F877A board with a LCD display and a RS232 port. I receive continuously some info from the RS232 port, and I want to display only one info from the RS232 stream.
Here is the RS232 stream :
ADCO 050622013932 8
OPTARIF HC.. <
ISOUSC 45 ?
HCHC 000000000 F
HCHP 000000001 T
PTEC HP..
IINST 000 W
IMAX 000 ?
PAPP 00000 !
HHPHC A ,
MOTDETAT 000000 B
This is repeated all the time.
The line I am interested of is "HCHC 000000000 F" and especially the value "000000000" which will change of course.
I wrote a basic program, but I am not very firendly with string manipulation. Anyway here is my code for the moment :
#include <16F877.H>
#use rs232(baud=1200, parity=E, bits=7, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
#include "lcd.h"
#include <string.h>
#define BUFFER_SIZE 20
BYTE buffer[BUFFER_SIZE];
BYTE next_in = 0;
BYTE next_out = 0;
#int_rda
void serial_isr() {
int t;
buffer[next_in]=getc();
t=next_in;
// Buffer full !!
if(next_in==next_out) next_in=t;
BYTE bgetc()
BYTE c;
while(!bkbhit) ;
c=buffer[next_out];
return(c);
void my_get_string(char* s, unsigned int8 max)
unsigned int8 len;
char c;
--max;
len=0;
do
c = bgetc() & 0x7F; // 7 bits so force data7 to 0
//lcd_putc(c);
//putc(c);
if(len<=max)
s[len++]=c;
c=0x0D;
} while(c!=0x0D);
s[len]=0;
char input_str[BUFFER_SIZE];
lcd_init();
lcd_putc("\fReady...\n");
SET_TRIS_A(0x00);
enable_interrupts(int_rda);
enable_interrupts(global);
my_get_string(input_str, BUFFER_SIZE-1);
lcd_putc("\f");
lcd_writestring(input_str);
output_bit(PIN_A0, !input(PIN_A0));
Of course this code was one of an example I modified.
Can you please have a look at this and let me know/help to do what I want ?
Thank you for your help.
Br,
Denis |
Dimmu
Posted: Fri Apr 11, 2008 2:43 pm |
Here is a simple example of code that should help you. Be careful that this code is not error proof.
I tested it with a 18F97J60.
You have to initialise the function with a call to
"Rs232Init();"
The your mainloop function must call as often as possible the function
"SerialTask();"
Under interrupt :
The bytes are stored into a buffer. In case of overflow, the complete buffer is lost ( due to the WRITE pointer that reached the READ pointer. no protection here )
Main function :
If the char '\n' is found, the last line of data received is treated at once. The function "HandleCommand" reads the first word of the line and compares it with a given keyword ( here : HCHC ). If found, the rest of the line is interpreted.
Best regards,
Dimmu
| Code: | #define RS232_BUFFER_SIZE 64
#define RS232_IDX_MASK RS232_BUFFER_SIZE - 1
#include "ctype.h"
#include "string.h"
#include "stdlib.h"
struct _RS232_BUFFER_T {
char DATA[RS232_BUFFER_SIZE];
unsigned int8 READ_IDX;
unsigned int8 WRITE_IDX;
} RS232_BUFFER;
// interrupt driven data reception
// each byte is written into the buffer
// the buffer must be read BEFORE overflow !
#int_rda
void Rs232ReceiveByte ( ) {
RS232_BUFFER.DATA[RS232_BUFFER.WRITE_IDX++] = getc();
RS232_BUFFER.WRITE_IDX &= RS232_IDX_MASK;
// same as a kbhit function
int1 Rs232DataAvailable ( void ) {
return (RS232_BUFFER.READ_IDX != RS232_BUFFER.WRITE_IDX);
// reads one byte from the buffer
char Rs232GetData ( void ) {
char c;
c = RS232_BUFFER.DATA[RS232_BUFFER.READ_IDX++];
RS232_BUFFER.READ_IDX &= RS232_IDX_MASK;
return c;
// initialisation function
// this function enables the interrupts !!
void Rs232Init ( void ) {
// Set the wsrite IDX to 1 and clear the input buffer
RS232_BUFFER.WRITE_IDX = 1;
RS232_BUFFER.DATA[0] = 0;
// enable interrupts
enable_interrupts ( INT_RDA );
enable_interrupts ( GLOBAL );
// A delay is added to clear any pending data
// this can be removed if necessary
delay_ms ( 100 );
// Now clear the input buffer
RS232_BUFFER.WRITE_IDX = 0;
RS232_BUFFER.READ_IDX = 0;
// reads a string value from the current position ( only alphanum values )
// no provision is taken to ensure that the input string
// is big enough to content the input data
// However the returned string shall never be greater than the input buffer
void GetString ( char * STR ) {
int1 LOOP = TRUE;
char c;
while ( LOOP ) {
if ( Rs232DataAvailable() ) {
c = Rs232GetData();
putc ( c );
if ( isalnum ( c ) )
*STR++ = c;
LOOP = FALSE;
*STR = 0;
// skips the blank chars from a given string and returns the
// number of shar skipped
// only the blank chars are removed, not the TABS, ...
int8 SkipBlank ( char * DATA ) {
int8 IDX = 0;
while ( DATA[IDX] == ' ' ) {
IDX++;
return IDX;
// copy the next token from string SOURCE into sting DEST
// the token is delimited by the trailing blanks
// the heading blanks are skipped
int8 CopyToken ( char * DEST, char * SOURCE ) {
int8 IDX = 0;
char c;
IDX = SkipBlank ( SOURCE );
SOURCE += IDX;
while ( TRUE ) {
c = *SOURCE++;
if ( ( c == ' ' ) || ( c == 0 ) )
*DEST++ = c;
IDX++;
*DEST = 0;
return IDX;
// reads the input string and handles the data
void HandleCommand ( char * DATA ) {
char CMD[32];
char VALID_CMD[5];
int8 DATA_IDX = 0;
int32 VALUE;
// copy first token of data into CMD
// and save the current size of the token
DATA_IDX += CopyToken ( CMD, DATA );
strcpy ( VALID_CMD, "HCHC" );
if ( strcmp ( VALID_CMD, CMD ) == 0 ) {
// increase DATA in order to point to the next element from the string
DATA += DATA_IDX;
printf ( "HCHC found ==> " );
// read the element ( must be the desired value )
printf ( "string value = %s", CMD );
// convert the string into an int32 value
VALUE = atoi32( CMD );
printf ( " ==> numeric value = %lu \n", VALUE );
void SerialTask ( void ) {
static char DATA[32];
static char IDX = 0;
char c;
while ( Rs232DataAvailable() ) {
c = Rs232GetData();
putc ( c );
// BackSpace
if ( c == 8 ) {
if ( IDX != 0 )
IDX--;
else if ( c == '\n' ) {
DATA[IDX] = 0;
HandleCommand( DATA );
IDX = 0;
DATA[0] = 0;
// Send ACK
putc ( 0x07 );
else if ( c == '\r' ) {
// nothing to do !
else {
if ( IDX < 32 ) {
DATA[IDX++] = c;
tyhon Guest
| Re: newbe programing help |
Posted: Sat Apr 12, 2008 7:28 am |
[quote="Anonymous"]Hi all,
you can post circuit ? |
tyhon Guest
Posted: Sat Apr 12, 2008 7:30 am |
| you can post circuit on forum? |
Posted: Thu Apr 17, 2008 9:13 am |
Hi, Yes I can post the schématics, but what part do you need?
I still not had time to test the code, but hope to have time next week.
I keep you posted.
Br
Denis |
