HI
I have made a webpage at 192.168.1.200 at port 21000
now i configured my controller to establish TCP connection
For it it sends request (ARP)
which is responded by
stand alone system by
ARP response and then system is ok
but
web server doesnot respond to ARP request
what could be the reason..
Thanks _________________ sohail khan
Douglas Kennedy
Posted: Thu Apr 17, 2008 8:42 am
I would start with the basic datagrams and double check them
If the data grams look to be coded well then I would install a packet sniffer on a pC and look at the individual packets. I used Ethereal several years ago when writing a server. PIC based servers are not fully compliant. TCP expects the servers to re sequence packets that are received out of order and to request resends of missing packets. You need an expansive packet stack to store several packets of up to 1K plus bytes each. PIC based code ignores this and works on average because it often restricts use to crisp exchanges of data with limited size or to intra nets where out of sequence isn't an issue. Example sending a large jpg file may glitch occasionally if the web picks paths that allow packets to get out of sequence or even mangled.
/////////////// Datagrams /////////////////////////////
// PING
// 1) PIC receives MAc 806 [ ARP type 0001 protocol 800 sub type 0001]
// 2) PIC sends MAC 806 [ ARP type 0001 protocol 800 0002] +PIC hardware address
// 3) PIC receives MAC 800 [IP protocol 01 [ICMP type 800] ]
// 4) PIC sends MAC 800 [IP protocol 01 [ICMP type 000] ]
// TCP ... SYN and FIN take up sequence numbers
// ------------ host requests a socket ------------------------------------------
// 1) PIC receives MAC 800 [(48 bytes)IP protocol 06 TCP [ SYN seq x ack --- ] options but no payload
// 2) PIC sends MAC 800 [(48 bytes)IP 06 TCP [ SYN ACK seq y ack x+1 ] options but no payload
// but SYN (1) received takes up a seq# thus x+1
// 3) PIC receives MAC 800 [(40 bytes)IP 06 TCP [ ACK seq x+1 ] no payload
// x+1 shows sender saw thePIC's SYN(see 2 above)
// socket is now established
// a timer is set to timeout if no request is sent to PIC
// 4) PIC receives MAC 800 [(40+payload)IP 06 TCP [ ACK seq x+1 ack y+1 ]
// +payload data GET HTML filename]
// 5) PIC sends MAC 800 [(40+payload)IP 06 TCP [ ACK (FIN if done)
// seq y+1 ack recv'd seq# (x+1)+size of received payload
// +payload data of HTML
// 6) PIC continues to send packets and receive ACKs until done (PIC sends FIN)
// a timer is set to force socket to close if client
// doesn't respond
// 7) PIC receives MAC 800 [(40 bytes)IP 06 TCP [ ACK ] no payload
// any remaining ACK's to sent packets
// 8) PIC receives MAC 800 [(40 bytes)IP 06 TCP [ FIN ACK ] no payload
// this confirms receipt of our FIN
// 9) PIC sends MAC 800 [(40 bytes)IP 06 TCP [ ACK ] no payload
// this is the LAST ACK
// socket is now closed
// ----------- client sends PIC a FIN during PIC's transmission of data -----------------
// 1) PIC receives MAC 800 [(40 bytes)IP 06 TCP [ FIN ACK ] no payload
// 2) PIC sends MAC 800 [(40 bytes)IP 06 TCP [ FIN ACK ] no payload
// this confirms receipt of the FIN
