E_KARVELAs
Joined: 14 Feb 2007 Posts: 46 Location: Greece & Cyprus
1s int TIMER1 external 32.768 Real-Time Clock finally work |
Posted: Wed Apr 16, 2008 9:57 am |
HI
I'm posting this code as help for people who need some help starting with Real-Time Clock Counts Seconds, Minutes using interrupt TIMER1 with External asynchronous crystal 32.768Khz and 33pF caps on Pins between pins T1OSI (input) and T1OSO (amplifier output). (Look at data sheets).
I had had an issue of my self with this code. I couldn't have exactly 1sec interrupt. I was always 1-2 sec forward with my (casio) watch. Searching the forum didn't find exactly where was the issue, until i look at the data sheets picture and found that the oscillator circuit, shown in Figure 12-3, should be located as close as possible to the microcontroller. Grounded with Vss <<LOOK AT THE PICTURE>> so i give a try and noticed that there was "NO MORE ERROR".
This code use internal 8MHZ crystal with 32.768 kHz crystal for RTC, flexy_lcd.c driver for 2x16 LCD can be found in the forum.
#include <18F2550.h>
#device ICD=TRUE
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES PUT //Power Up Timer
#FUSES NOIESO //NO Internal External Switch Over mode enabled
#FUSES NOPBADEN //NO PORTB pins are configured as digital I/O on RESET
#FUSES NOLPT1OSC //Timer1 configured for higher power operation
#FUSES PLL12 //Divide By 12(48MHz oscillator input)
#FUSES CPUDIV1
#FUSES NOUSBDIV //NO USB clock source comes from primary oscillator
#FUSES NOVREGEN //NO USB voltage regulator disabled
#use delay(clock=8000000)
#include <flexy_lcd.c>
int sec=0;
int min=0;
int hour=0;
int1 flg=false;
long t=0;
void main(){
setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1|T1_CLK_OUT);
lcd_init();
setup_oscillator(OSC_8MHZ|OSC_INTRC|OSC_PLL_ON); //<-- internal //8MHZ crystal with PLL ON 8X4=32MHZ
for(;;){
if(flg==true){
set_timer1(32768); //2^16= 65536/2 = 32768 * 1/32.768Hz <--- (1sec)
setup_timer_1(T1_EXTERNAL|T1_CLK_OUT);
if (++sec>59){
sec=0;
if(++min>59){
min=0;
hour++;
if(++hour>23){
hour=0;
lcd_gotoxy(1,1);
printf(lcd_putc"%02u:%02u:%02u %6Lu"hour,min,sec,t);
flg=false;
#int_TIMER1
void TIMER1_isr(void)
flg=true;
_________________ ---- GREECE ---- |
Douglas Kennedy
Posted: Thu Apr 17, 2008 8:12 am |
An I missing something? The internal osc is 8Mhz and the pll takes it up to 32Mhz but your use delay is 8Mhz. Now I know there aren't any situations in your code where the use delay would be critical but it may be an accident just waiting to happen. |
E_KARVELAs
Posted: Thu Apr 17, 2008 8:28 am |
Douglas Kennedy wrote: | An I missing something? The internal osc is 8Mhz and the pll takes it up to 32Mhz but your use delay is 8Mhz. Now I know there aren't any situations in your code where the use delay would be critical but it may be an accident just waiting to happen. |
Nop u are Not Xexexex I now I should put delay(32000000) but did'nt work and i dont now why.
So i change it back to 8Mhz delay and the code again work .
Very strange but works _________________ ---- GREECE ---- |
E_KARVELAs
Thanks goes to Neutone. |
Posted: Thu Apr 17, 2008 8:51 am |
Code Now improved for more performance and accuracy
This will improve performance and accuracy. There will be no error introduced by setting the timer to 32768 after the timer has incremented to 3 or 4.
Thanks to Neutone for the modification.
#device ICD=TRUE
#FUSES CPUDIV1
#Byte TMR1H = 0xFCF // TIMER1 HIGH BYTE LOOK DATASHEET
#Byte T1CON = 0xFCD //TIMER1 CONFIG REGISTER LOOK DATASHEET
int sec=0;
int min=0;
int hour=0;
int1 flg=false;
void main(){
lcd_init();
//<-- internal 8MHZ crystal with PLL ON 8X4=32MHZ
for(;;){
if(flg==true){
setup_timer_1(T1_EXTERNAL|T1_CLK_OUT); // external TIMER1 with
// 32.768Khz ,clock out for oscillator,asynchronus mode
if (++sec>59){
sec=0;
if(++min>59){
min=0;
hour++;
if(++hour>23){
hour=0;
lcd_gotoxy(1,1);
printf(lcd_putc"%02u:%02u:%02u "hour,min,sec);
flg=false;
#int_TIMER1
void TIMER1_isr() // 2^16= 65536/2 = 32768 * 1/32.768Hz <--- (1sec)
bit_clear(T1CON,7); //Enable access to the individual bytes of the timer register
Bit_Set(TMR1H,7); //Add 32768 to timer1 by setting high bit or timer register
Bit_Set(T1CON,7); //Disable access to the individual bytes of the timer register
flg=true;
Posted: Thu Apr 17, 2008 8:59 am |
Not on this chip.....
The PLL, is not available on the internal oscillator on this chip. On some other chips, there is an internal software switchable PLL, which can be enabled (the 2480 for example), but not on the 2550. There shouldn't actually be a OSC_PLL_ON setting for this chip at all (fault in the CCS file), since the only PLL present, is the one enabled by the fuses, feeding the USB clock.
If you look at the clock diagram for the chip, you will see that there is no PLL after the internal oscillator connects to control multiplexer.
8MHz is the maximum internal clock available on this chip.
E_KARVELAs
Posted: Thu Apr 17, 2008 9:30 am |
Ttelmah wrote: | Not on this chip.....
Damn Right , Nice!!! I just have a look at the datasheets and notice there's PLL for external oscillator only NOT FOR INTERNAL .thanks
ericne Guest
Posted: Sat Apr 25, 2009 7:08 pm |
Let me say first of all thank you E_KARVELA for your work on this.
The question I have is over the TMR1H and T1CON values which I see that are being set to 0xFCF and 0xFCD respectively. What is the significance of these numbers? I looked on the datasheet for the 2550, but couldn't figure out why you would want a 12-bit number there, or how I would modify that value for a different device. |
E_KARVELAs
Posted: Tue Apr 28, 2009 3:37 am |
ericne wrote: | Let me say first of all thank you E_KARVELA for your work on this.
Hi
Before start using TMR1H & T1CON and every SFR(Special Function Register) you have to Define the address first for the ccsc compiler. If you look at the datasheets of 2550 (address SFR ) you will see that the TMR1H address is 0xFCF and T1CON address is 0xFCD. Thats all.
Take care.
