Problems with Button Delay on 16f887
feederic
PostPosted: Tue Apr 08, 2008 8:42 pm     Reply with quote
I'm new to the PIC programming scene and have been teaching myself while programming a school project.
I've been having problems getting a button to react instantly in my code while using the A2D and case statements.
Namely, I've got a A2D converter controlling the speed of 4 scrolling LEDs. I have 4 buttons, one assigned to each LED, and I want the button to pause its corresponding LED if and only the LED is on.
My problem is I need to hold the button down for a half second (sometimes longer) to get it to react. Sometimes it will react 2 seconds later.
#include <16F887.h>             // header file for the PIC16F887
                                // includes built-in functions and constants
                                // for arguments/returns.
#use delay (clock = 4MHZ)
#use fast_io(A)                 // all other ports default to 'standard_io'
#use fast_io(B)                 // fast_io means the tris bits only change
#use fast_io(C)
#use fast_io(D)
#FUSES INTRC,NOWDT,NOPUT,NOMCLR,NOPROTECT,NOCPD,NOBROWNOUT,NOIESO,NOFCMEN,NOLVP
long int state_delay = 0;
int state_delay_temp = 0;
int mult = 20;
unsigned char state_led = 0;
struct adc_result
    int8 value;
    int1 new_flag;
    } adc_conversion;
void init_io()
    SET_TRIS_A(0x0F);   // bit 0 = output, 1 = input
    SET_TRIS_B(0x3F);   // bit 0 = output, 1 = input
    SET_TRIS_D(0xF0);
    SET_TRIS_C(0x00);
    OUTPUT_E(0x00);
void init_adc()
    // Set up RA0 as the only analog input, using VDD and VSS
    // as the references
    SETUP_ADC_PORTS(sAN0 | VSS_VDD);
    // Turn on ADC and use Fosc/8 as the conversion clock
    // (Fosc = 4MHz)
    SETUP_ADC(ADC_CLOCK_DIV_8);
    // Set channel for conversion to AN0 (on RA0)
    SET_ADC_CHANNEL(0);
    // start the first conversion
    READ_ADC(ADC_START_ONLY);
#INT_RTCC   // This function will be called on a Timer0 interrupt
void timer0_interrupt_service()
    // channel is always set to AN0.  Otherwise we might change
    // it here
    // Get last conversion result.
    adc_conversion.value = READ_ADC(ADC_READ_ONLY);
    adc_conversion.new_flag = 1;    // new value
   delay_ms(state_delay);
   state_led++;
    // start next conversion
    int switch_count = 0;
    int temp1 = 0;
    int led_display = 0;
    adc_conversion.value = 0;
    adc_conversion.new_flag = 0;
    init_io();
    init_adc();
    SETUP_TIMER_0(RTCC_INTERNAL | RTCC_DIV_256);
    ENABLE_INTERRUPTS(GLOBAL);
    ENABLE_INTERRUPTS(INT_RTCC);
        // look for a new conversion result
        if (adc_conversion.new_flag == 1)
            state_delay_temp = adc_conversion.value;
         state_delay = _mul(state_delay_temp, mult);
            led_display = 0;
     if (INPUT_STATE(PIN_B0) == 0 && state_led == 0)
            if (switch_count < 4)
                switch_count ++;
                if (switch_count == 4)
                    output_d(1);
            switch_count = 0;
if (INPUT_STATE(PIN_B1) == 0 && state_led == 1)
                switch_count ++;
                    output_d(2);
            switch_count = 0;
if (INPUT_STATE(PIN_B2) == 0 && state_led == 2)
                switch_count ++;
                    output_d(4);
            switch_count = 0;
if (INPUT_STATE(PIN_B3) == 0 && state_led == 3)
                switch_count ++;
                    output_d(8);
            switch_count = 0;
   switch (state_led)
         case 0:
            led_display = 1;
            if(INPUT_STATE(PIN_D7) == 1)
            state_led =1;
            OUTPUT_D(1);
         case 1:
            led_display = 2;
            if(INPUT_STATE(PIN_D6) == 1)
            state_led = 2;
            OUTPUT_D(2);
         case 2:
            led_display = 4;
               if(INPUT_STATE(PIN_D5) == 1)
            state_led = 3;
            OUTPUT_D(4);
         case 3:
            led_display = 8;
            if(INPUT_STATE(PIN_D4) == 1)
            state_led = 4;
            OUTPUT_D(8);
         case 4:
            state_led = 0;
         case 5:
            OUTPUT_D(led_display);
            state_led = 5;
I have a variable state_led that is being incremented in the Timer0 ISR, this increment will cause the next led to light in the case statements.
I would greatly appreciate any help.
Matro
PostPosted: Wed Apr 09, 2008 1:36 am     Reply with quote
I would have coded that differently.
Do a read_adc() only once per loop (endless loop of the main()).
Use interrupt-on-change feature of the port B to handle button pushes.
Here in your timer interrupt, the read_adc() will slow down the code and the delay_ms() too.
When this interrupt is triggered, main() execution is stopped so if this interrupt continuously "breaks" the main() the reaction delay will be very long.
I think you don't need to acquire very often the new adc_value (once per loop should be sufficient) so place the read in the main() loop.
And (if your buttons are connected to port B) use the interrupt-on-change of this port to handle button changes.
Matro.
PostPosted: Wed Apr 09, 2008 12:26 pm     Reply with quote
Thank you Matro, I knew the problem was around the a2d conversion but didn't know how to remedy it.
I will try out all of your suggestions immediately!
PostPosted: Thu Apr 10, 2008 4:53 pm     Reply with quote
I tried the suggested fixes, and have had some success.
The button delays are gone, and the a2d has smoothed out when turning the pot.
The only issue I have right now is being able to generate a interrupt the whole time an LED is lit.
For clarity, I have RB1-4 assigned to LEDs 1-4 (on PortD)
When LED 1 is on and button RB1 is pushed I want to generate the inerrupt.
When LED 2 is on and button RB2 is pushed I want ""
...and so on.
I'm pretty much using this code in the RB interrupt code.
                switch_count ++;
                    output_d(4);
            switch_count = 0;
anyone have any suggestions??
feederic
PostPosted: Thu Apr 10, 2008 4:59 pm     Reply with quote
That was my post above.
I also did change the button polling for portB to interrupt on change.
feederic
PostPosted: Wed Apr 16, 2008 8:42 pm     Reply with quote
Hi everyone, I'm still having a few problems I can't work out.
The buttons work fine except when the LED speed is slow. When the delay coming from the A2D produces a large value, the portB interrupts work unless we hold the button down for about a second.
My code thus far:
#use fast_io(C)
#use fast_io(D)
                              // when we explicitly set them.
// FUSES sets the PIC16F887 Configuration Words.  See top of the header file
// 16F887.h for fuse option constants.
int mult = 20;
int switch_count1 = 0;
int temp = 0;
struct adc_result
    int8 value;         // ADC built-in functions default to 8 bit result.
    int1 new_flag;      // 1-bit falg to indicate a new (fresh) value
 } adc_conversion;
void init_io()
    // set up PORTA so RA0 is an input for the ADC, RA1-RA7 are outputs
    // set up PORTB so RB0 is an input for the switch SW1, RB1-RB7 are outputs
   SET_TRIS_D(0xF0);
    // set up remaining ports to be all outputs
    SET_TRIS_C(0x00);
     PORT_B_PULLUPS(0x3f);
    OUTPUT_E(0x00);
void init_adc()
    // (Fosc = 4MHz)
    SET_ADC_CHANNEL(0);
    // it here
   state_led++;
#INT_RB
void button_interrupt_service()
   if (INPUT_STATE(PIN_B1) != 1 )
      output_d(1);
       if(input_state(pin_b5) == 0)
   if (INPUT_STATE(PIN_B2) != 1 )
      output_d(2);
   if (INPUT_STATE(PIN_B3) != 1 )
      output_d(4);
   if (INPUT_STATE(PIN_B4) != 1 )
      output_d(8);
  //  int1 led_bar_right = 0; // default is led bar graph starting on the left (DS0)
    int switch_count = 0;   // used for debouncing the switch
    int switch_count1 = 0;           // used to compute the number of LED "bars" to display
 //   int temp1 = 0;           temporary working variable
  //  int led_display = 0;    // led display value
   int sound = 0;
      int start =1;
   int temp = 0;
 // initialize global variables
    // Set up MCU
    init_io();
    init_adc();
        // Timer 0 runs off internal clock with 1:256 prescaler
        // This means it should run over every ((256*256)/(4MHz/4)) = 65.5ms
        // It will be used to start an ADC conversion.
    ENABLE_INTERRUPTS(GLOBAL);          // enable interrupts in general to be active
    ENABLE_INTERRUPTS(INT_RTCC);        // enable the interrupt for Timer 0
   ENABLE_INTERRUPTS(INT_RB);
if( start ==1)
            adc_conversion.new_flag = 0;        // reset flag
          led_display = 0; // clear display variable
   if (INPUT_STATE(PIN_D7) == 1 && INPUT_STATE(PIN_D6) == 1 && INPUT_STATE(PIN_D5) == 1 && INPUT_STATE(PIN_D5) == 1)
        { // switch is low when pressed
            { // increment the count on all consecutive checks where switch is pressed
              // to a max of 3
                switch_count ++;
                // if we've seen 3 consecutive checks where the switch is pressed
                // it's considered a valid switch press.  Reverse the bar graph
                    state_led = 6;
        { // anytime switch is detected as not pressed, reset the count
            switch_count = 0;
if(INPUT_STATE(PIN_A2) == 1)
while(led_display ==1)
         output_high(PIN_c6);
           delay_us(500);
           output_low(PIN_c6);
           delay_us(500);
while(led_display ==2)
           delay_us(600);
           output_low(PIN_c6);
           delay_us(600);
while(led_display==4)
           delay_us(700);
           output_low(PIN_c6);
           delay_us(700);
while(led_display ==8)
           delay_us(800);
           output_low(PIN_c6);
           delay_us(800);
   switch (state_led)
         case 0:
            led_display = 1;
            state_led =1;
            OUTPUT_D(1);
         case 1:
            led_display = 2;
            state_led = 2;
            OUTPUT_D(2);
         case 2:
            led_display = 4;
            state_led = 3;
            OUTPUT_D(4);
         case 3:
            led_display = 8;
            state_led = 4;
            OUTPUT_D(8);
         case 4:
            state_led = 0;
         case 5:
            state_led = 5;
         case 6:
            OUTPUT_D(0x0f);
            state_led=4;
I'm pretty sure my problem lies here:
    // it here
   [b]delay_ms(state_delay);[/b]
   state_led++;
When the delay is large I can't generate an interrupt immediately. Is there any way I can keep this delay going while being able to generate an interrupt on portB?
I'm fresh out of ideas right now.
PostPosted: Wed Apr 16, 2008 9:00 pm     Reply with quote
Look at multi-tasking techniques:
http://www.ccsinfo.com/forum/viewtopic.php?t=17189
feederic
PostPosted: Wed Apr 16, 2008 9:22 pm     Reply with quote
That is an excellent link!
I'll post up progress hopefully by monday.
feederic
PostPosted: Mon Apr 21, 2008 12:58 am     Reply with quote
Thanks PCM PROGRAMMER and MATRO!
Everything is working as desired! Smile
