KU5D
Joined: 10 Feb 2008 Posts: 46 Location: Asheville, North Carolina
PICDEM.net board |
Posted: Wed Apr 16, 2008 5:49 pm |
This is likely a dumb question, but I'm searching the forums for any examples using the PICDEM.net demo board Ethernet widget. The documentation discusses examples using the C-18 compiler (which I have), but I'd like to see what I can do with my CCS compiler and the ICD-U40. I've just acquired this board and it has an 18F452, which I'd like to replace with the 18F4525, but I'd like to get it up and talking to prove that the hardware works before I make any changes.
Cheers,
doug _________________ Confidence is the feeling you have right before you fully understand the situation... |
KU5D
Posted: Sat Apr 19, 2008 7:58 pm |
I'll bump this once... _________________ Confidence is the feeling you have right before you fully understand the situation... |
asmallri
Joined: 12 Aug 2004 Posts: 1635 Location: Perth, Australia
Posted: Sat Apr 19, 2008 10:00 pm |
If you are changing the PIC then the 4620 is a better choice for network applications.
The CCS stack has drivers for the RTL8019AS Ethernet controller _________________ Regards, Andrew
