ferrousduke
Joined: 31 Mar 2008 Posts: 29 Location: Mumbai, India
data storage |
Posted: Sun Apr 13, 2008 2:55 pm |
hello,
I have to store the value of the analog channel into the mc memory. anyone can help ? data appears at AN1 with sampling rate of 1 ms. i need to store that value instantaneously.
any basic commands for that? |
Matro Guest
Posted: Mon Apr 14, 2008 1:50 am |
Which memory?
The EEPROM or program memory will never be fast enough to allow a write every 1ms.
Matro. |
ferrousduke
Posted: Wed Apr 16, 2008 3:50 am |
EEPROM. I guess I have to slow down the process. I dont want it more than 30 ms. how fast can it write into memory ? |
Matro Guest
Posted: Wed Apr 16, 2008 4:16 am |
It depends on your chip and the Xtal frequency you are using.
The best is to perform a test :
- generate a rising edge on a spare pin
- run the write_eeprom() command
- generate a falling edge on the same spare pin
You just have to look at the pin with a scope to know how long it takes to write in EEPROM.
Take 1.5x or 2x this time to be sure.
A good thing could be to use asynchronous write. So the chip can continue processing data during the EEPROM writes :
#device(write_eeprom=ASYNC)
Don't use this directive to test the writing time but only for the real application.
Matro. |
Humberto
Posted: Wed Apr 16, 2008 7:24 am |
A FRAM would be your best choise.
A FRAM internally has a structure similar to a DRAM (dynamic RAM), but the storage of
data is made by means of a ferroelectric effect, by opposition to the conservation
of the load in the intrinsic capacitor in a dynamic RAM of floating gate.
Its main features:
- very fast access time.
- virtually limitless writings.
- data retention without energy consumption.
You will search for some application in this forum.
Humberto |
SherpaDoug
Posted: Wed Apr 16, 2008 7:32 am |
Also note that EEPROM has a finite number of write cycles before it fails. The PIC I am using is rated for 1 million write cycles. If you were to write the same location every 1ms you would wear it out in 1000 seconds, about 17 minutes. _________________ The search for better is endless. Instead simply find very good and get the job done. |
Matro Guest
Posted: Wed Apr 16, 2008 7:41 am |
SherpaDoug wrote: | Also note that EEPROM has a finite number of write cycles before it fails. The PIC I am using is rated for 1 million write cycles. If you were to write the same location every 1ms you would wear it out in 1000 seconds, about 17 minutes. |
So right a comment.
Even taking the given worst case (30 ms), if each write is at the same location and taking 1,000,000 write cycles as a lifetime, the EEPROM will fail after 8h 20min.
Matro. |
Posted: Wed Apr 16, 2008 10:59 am |
Quote: | data appears at AN1 with sampling rate of 1 ms. i need to store that value instantaneously. | What do you mean with 'store'? How long do you want to remember the data? In the discussion above everybody assumes you want to remember the data in between power cycles, but is this true? For example, if losing data after a power cycle or reset is no problem than you can store the data in internal RAM which has no speed problems.
How many data samples do you want to store?
How many bits is every sample? |
ferrousduke
Posted: Wed Apr 16, 2008 2:54 pm |
I m using 18f4550 with crystal 20 Mhz. I have this position sensor from Renishaw attached to AN1.. (just an assumption) data in this terms would be a single axis coordinate. but I want to store that particular coordinate associating with XY coordinates, so the set of data comprises of 3 coordinates.. (X-Y-Z).. XY will be simply incremented at particular cycles. Z coordinate I need to sample. Moreover, the scanning should take lot of time which means gathering of data will be for long time and I need to save it temporarily in my controller till my USB talks to it and then I can transfer the file to PC. I hope I put myself in correct words.. |
Posted: Wed Apr 16, 2008 8:17 pm |
We are trying to determine what type of memory is needed. For example, the easiest to use memory is the internal RAM but this will loose it's contents when power is removed. EEPROM doesn't loose it's contents but has other problems.
You already told us the data is coming in at a rate of 1 sample each 30ms, and if possible you would like to speed this up to 1 sample/ms.
To give a good suggestion we need an answer to the following questions:
Quote: | I need to save it temporarily in my controller till my USB talks to it and then I can transfer the file to PC. | How temporarily do you have to store the data?
And is (battery) power available without interruption during this period?
What is the maximum amount of data you have to store before transferring to the PC?
In order to calculate this you need to know:
- The maximum number of sampled coordinates per session.
- The sampling resolution for the Z-coordinate (PIC A/D converter can be set to 8 or 10-bit resolution).
- Number of bytes required for a single X and Y coordinate. |
