madtoilet
rs232 conflicts |
Posted: Tue Apr 15, 2008 2:37 pm |
i have the following setting:
#use rs232(baud=4800, bits=8, parity=N, stop=1, xmit=PIN_C6, rcv=PIN_C7, stream=GSM, ERRORS)
but when i use the follow functions:
void my_get_string(void) {
char c;
int i=4;
int count=0;
unsigned char temp[68]="$GPR";
output_low(PIN_B7);
start:
c = getc();
if(c == '$')
output_high(PIN_B7);
output_low(PIN_B7);
c = getc();
if(c == 'G'){
// output_low(PIN_B7);
//output_low(PIN_B7);
c = getc();
if (c == 'P'){
c = getc();
if (c == 'R'){
while(count < 55){
temp[i]= getc();
i++;
count++;
goto ending;
back:
goto back;*/
goto start;
ending:
temp[i] = 0;
cursor_position(0x81);
out_lcd_string(temp);
delay_ms(1500);
and
Code: | void gsm_call(void)
char c;
output_low(PIN_B5);
delay_ms(800);
output_low(PIN_C4);
output_high(PIN_C5);
fprintf(GSM, "AT+CMGF=1\r\n");
delay_ms(2050);
fprintf(GSM,"AT+CMGS=\"%s\"\r\n",num);
delay_ms(2000);
fprintf(GSM, "check\r\n");
fputc(0x1A,GSM);
delay_ms(3000);
the my_get_string function stops working but the gsm_call continues to work correctly.
however, when i comment stream=GSM out of the configuration, the my_get_string works.
Is there a reason that this is happening? |
