12F675 -> PIN_A3 doesn't work
i2c2k
PostPosted: Sat Jul 09, 2005 4:03 am     Reply with quote
hi,
i wrote a little programme to drive 3 leds and a MOSFET driver.
unfortunately the blue led doesn't work because i get only floating level at the GPIO3 output.
here's the code:
#include<12F675.h>
#fuses INTRC, NOWDT, NOCPD, NOPROTECT, NOMCLR, NOPUT, INTRC_IO, NOBROWNOUT
#use delay (clock=4000000)
#use fast_io(A)
#define LED_RED PIN_A5
#define LED_WHITE PIN_A4
#define LED_BLUE PIN_A3
#define PWM_OUTPUT PIN_A0
#define BUTTON_INPUT PIN_A2
   port_a_pullups(false);
   setup_adc(ADC_OFF);
   setup_adc_ports (NO_ANALOGS);
   set_tris_a(0b00000100);
   output_a(0xff);
   while (1)
thanks!
PostPosted: Sat Jul 09, 2005 4:29 am     Reply with quote
It never will.
I'm afraid to say 'RTFM'....
On the 12F675, if you read the data sheet, you will find that pin GP3, is _only_ useable as an input. This is because the pin is multiplexed with the programming voltage input, which has to be able to pull the pin well above the +ve supply rail. As such there cannot be a pull-up FET present on the pin, and so the pins where this is done, are always made either 'input only', or 'open collector outputs'. On the 675, it is made input only.
Modify your hardware and your code. Move the LED to pin A2, and put the input push button on A3.
i2c2k
PostPosted: Sat Jul 09, 2005 4:31 am     Reply with quote
ok, thanks!
40inD
PostPosted: Mon Apr 14, 2008 11:10 pm     Reply with quote
Is PIN_A2 used for something like this too? In my PIC it does not want to go HIGH.
Matro
PostPosted: Tue Apr 15, 2008 1:30 am     Reply with quote
Nothing similar for this pin but you have to activate the weak pull-up.
Look for "WPU" register int he datasheet.
Matro.
40inD
PostPosted: Tue Apr 15, 2008 2:04 am     Reply with quote
In datasheet:
The weak pull-up device is automatically disabled if the pin is in Output mode
Matro
PostPosted: Tue Apr 15, 2008 2:19 am     Reply with quote
40inD wrote:
In datasheet:
If your pin is an output you should be able to have a high level. The pin isn't an open drain one.
Check that COUT is disabled.
You can post a short excerpt of your code.
Matro.
40inD
PostPosted: Tue Apr 15, 2008 2:28 am     Reply with quote
How to check this?
Matro
PostPosted: Tue Apr 15, 2008 2:52 am     Reply with quote
These 2 lines shall be present in your code
   setup_comparator(NC_NC);
   setup_vref(FALSE);
You can also read CM2:CM0 value during code execution and check that it is 0b111 (for example with a "if" statement that toggles a LED).
Notice that the comparator is active by default. That's why you have to disable it.
Matro.
40inD
PostPosted: Tue Apr 15, 2008 3:02 am     Reply with quote
Hmm. Not helps!
I just moved output to other pin...
