variables passed
new
variables passed
PostPosted: Mon Apr 14, 2008 4:05 pm     Reply with quote
How are function parameters passed? If I was to store data in internal memory I need to prevent interference with the compilers memory usage.
PostPosted: Mon Apr 14, 2008 4:22 pm     Reply with quote
Don't write to an arbitrary address in RAM. Instead, declare an array,
and write to the array. Then you won't have a conflict with the
compiler's internal variables. In other words, do everything in the
standard way, and let the compiler handle the memory allocation.
