Problem with LCD
hanamichi
Problem with LCD
PostPosted: Mon Apr 14, 2008 2:19 pm     Reply with quote
hai all..
I'm doing a project on RFID and needs a LCD as a display panel. My problem is my LCD doen't work as expected. Can anyone here helps me to check my codes??????Here is my source code..I really needs a help here!!!!!!
#include <16f876A.h>
#use delay(clock=400000)
#fuses hs, nowdt, noprotect
#byte PORTA=5
#byte PORTB=6
#byte PORTC=7
# define use_portb_lcd true
#include <lcd.c>
   set_tris_a(0x03);
   lcd_init();
   do
    if(input(pin_a2)==1 && input(pin_a1)==0 && input(pin_a0)==0)
     lcd_putc("\f Welcome ");
     lcd_putc("\n PlsMoveDetector ");
     delay_ms(100000);
      lcd_putc("\f");
      lcd_putc("");
    if(input(pin_a2)==1 && input(pin_a1)==1 && input(pin_a0)==0)
     lcd_putc("\f Item 1 detected ");
     lcd_putc("\n Find your item1 ");
     delay_ms(100000);
      lcd_putc("\f");
      lcd_putc("");
      if(input(pin_a2)==1 && input(pin_a1)==0 && input(pin_a0)==1)
      lcd_putc("\f  Item 2 detected");
      lcd_putc("\n  Find your item2");
      delay_ms(100000);
      lcd_putc("\f");
      lcd_putc("");
   }while(1);
PostPosted: Mon Apr 14, 2008 2:29 pm     Reply with quote
You typed in the incorrect frequency. You typed 400 KHz, and you
should have typed 4 MHz.
