Font for 14seg LED display (binary notation?)
kd5uzz
PostPosted: Mon Apr 14, 2008 10:31 am     Reply with quote
I just recieved a part from allelectronics (CAT# DSY-1) that includes a 7 char 14seg display. I need to create a font for this device. I plan on storing the bit pattern array in rom via the CONST statement. The elements of this array are to be 'long'. I would like to use binary notation, but I have at few questions:
1. I've never used binary notation before, would it be acceptible in this situation? Or is there a better option?
2. Does CCS support binary notation? I can't find any mention of it in the help file. Can I even use binary notation for a long?
3. Can someone give me an example of binary notation?
Here is my code so far. Display.A[] is what the program will modify to change the display, BA[] holds the bit pattern that is to be sent to the display. SetupDisplay() will be called to perform the conversion from the char Display.A[] to the bit pattern in Display.BA[]. The bit pattern will be pulled from the ALPHAFont. Same goes for Display.N[] except its a 7seg display. The display will be updated 100 times a second, and the contents of the display will be updated 8 times a second.
Any suggestions are welcome. I've never done this type of program before.
I should mention that
#include <16F877a.h>
#use delay(clock=20000000)             //clock speed
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7,ERRORS)
#define TIMER2PERIOD 250
#define MAIL   0
#define PHONE  1
#define STORAGE   2
#define NETWORK   3
#define AC1 4
#define AC2 5
#define NC1 6
#define NC2 7
int DoDSYSetup,QuarterSecondPassed,HalfSecondPassed,SecondPassed,Timer2Count;
LONG CONST ALPHAFont[90] = {};
INT CONST NUMERICFont[10] = {};
struct typeserialpacket {
   char A[7];
   char N[4];
   long BA[7];
   int BN[4];
   int Icons;
} Display;
#int_TIMER2
void TIMER2_ISR(){
   //this function should be called X times a second
   static int TIMER2Counter;
   static int DSYSetup;
   int i;
   TIMER2Counter++;
   DSYSetup++;
   if (DSYSetup == TIMER2PERIOD/8){
      DoDSYSetup = TRUE;
      DSYSetup = 0;
   if ((Timer2Counter == TIMER2PERIOD/4) || (Timer2Counter == TIMER2PERIOD/4*2) || (Timer2Counter == TIMER2PERIOD/4*3) || (Timer2Counter == TIMER2PERIOD/4*4)){
      QuarterSecondPassed = TRUE;
   if ((Timer2Counter == TIMER2PERIOD/2) || (Timer2Counter == TIMER2PERIOD/2*2)){
      HalfSecondPassed = TRUE;
   if (Timer2Counter == TIMER2PERIOD){
      Timer2Counter = 0;
void SetupDisplay(){
   int i;
   for (i=0;i<=6;++i){
void main(){
   printf("DSY-1 from All Electronics Test");
   setup_timer_2(T2_DIV_BY_16,250,5);
   while(TRUE){
      if (DoDSYSetup == TRUE){
         DoDSYSetup = !DoDSYSetup;
         SetupDisplay();
PostPosted: Mon Apr 14, 2008 11:01 am     Reply with quote
This thread shows how to do a numeric font for a 14-segment LCD.
http://www.ccsinfo.com/forum/viewtopic.php?t=33377&start=11
kd5uzz
PostPosted: Mon Apr 14, 2008 12:02 pm     Reply with quote
That is great, thanks!
