#org 0x10000
pmuldoon
#org 0x10000
PostPosted: Mon Apr 14, 2008 10:44 am     Reply with quote
I am trying to compile a bootloader program to reside in high memory by using the following directives:
PCH Compiler version 4.071
#include <18F6722.h>
#define MAX_LOADABLE 0x1F630
#org 0x0008, MAX_LOADABLE {}
and I get the following msgs:
--- Info 300 "bootloader.c" Line 62(27,28): More info: Segment at 00000-0FFFE (0000 used)
--- Info 300 "bootloader.c" Line 62(27,28): More info: Segment at 10000-1FFFE (0000 used)
--- Info 300 "bootloader.c" Line 62(27,28): More info: Attempted to create: 00008-1F630 for #org
*** Error 126 "bootloader.c" Line 62(27,28): Invalid ORG range
It doesn't seem to work with any value greater than 0xFFFF.
Even 0x10000 will fail.
The chip has 128K of program memory.
I can locate the program in the middle of memory by using 0xFFFF, but
the org directive doesn't seem to like a 5 digit hex number.
Am I just missing something obvious?
PostPosted: Mon Apr 14, 2008 10:49 am     Reply with quote
You are missing the solution in this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=31941
pmuldoon
PostPosted: Mon Apr 14, 2008 11:09 am     Reply with quote
Thanks, PCM.
You saved me again!
I never would have thought of that one.
I guess TheByteFactory code is pretty popular, eh?
Maybe you should be promoted to PCH?!
