wrong uart reading in 18F4431
40inD
PostPosted: Mon Apr 14, 2008 7:35 am     Reply with quote
I have trouble with18F4431 receiving data from 12F675. The Getc function returns garbage.
Here are the codes:
sender:
#use rs232(baud=9600, xmit=PIN_A4, rcv=PIN_A5)
char c;
putc(c)
receiver:
#use rs232(baud=9600, xmit=PIN_С6, rcv=PIN_С7)
char c;
c=getc(); //already wrong
printf(lcd_putc, "%c", c);
And the garbage depends on what's sending.
The signal from transmitter is OK. In Proteus all OK too.
andredurao
Re: wrong uart reading in 18F4431
PostPosted: Mon Apr 14, 2008 7:58 am     Reply with quote
strange... I tried to simulatte 18f4431 and my version of proteus didn't have the simulator model for that device,....wich version are you using?
Matro
PostPosted: Mon Apr 14, 2008 7:59 am     Reply with quote
Are both PIC running at the same voltage?
It's better to set up parity, bits and stop in the #use rs232 directive.
Matro.
PostPosted: Mon Apr 14, 2008 9:08 am     Reply with quote
What clock source are you using?.
Fuses?.
Clock statement?.
Connections (remember the ground...).
Power source?.
40inD
PostPosted: Mon Apr 14, 2008 10:45 pm     Reply with quote
18F4431 was only one free chip in my component box now, and I used it for simple tasks like rs232 and lcd output. For this reason I replaced it in Proteus with 18F452. The code works.
Not only at same voltage - at same DC source.
I tried to set many combinations of rs232 parameters - not helps.
For 18 i use 40Mhz crystal, for 12 - internal osc 4 MHz.
PICs are connected directly pin-to-pin.
Power source - 7805, 1 source for both pics.
Can't post fuses now because the code is at home and I - at work now Smile
PostPosted: Tue Apr 15, 2008 2:26 am     Reply with quote
Do you mean a 40MHz _crystal_, or a _oscillator module_?.
If the former, then this is your problem.
The maximum frequency specified for the internal oscillator module, using a crystal, on this chip, is 25MHz. Table 25-4 in the data sheet. What happens if you go over this, is that the oscillator generally runs, but locks onto the wrong overtone on the crystal, and typically gives 3/4 the specified frequency. No wonder the serial rates would be wrong....
To run most 18 chips at 40MHz, requires either using the PLL, or using an external oscillator module.
40inD
PostPosted: Tue Apr 15, 2008 2:54 am     Reply with quote
Hmmm... i will try 20Mhz crystal, but i always used 40 MHz with projects on this pic and never had problems... but i never used uart in this projects...
