Timer2 with 18F2431
Guest_18F2431
Timer2 with 18F2431
PostPosted: Mon Apr 14, 2008 1:44 am     Reply with quote
I need to generate a PWM manually, so i use the timer2 function.
I speak english language too bad to understand the help of the software.
setup_timer2(T2_DIV_BY_4,0xc0,2);
//sets the prescale as 4, period as 0xc0 and postscales as 2.
//At 20Mhz timer2 will increment every .8us in this
//setup overflows every 154.4us and interrupt every 308.2us
I use too an extern clock at 20Mhz and the 18F2431 PIC.
I would generate an overflow at 10 us.
If somebody could help me. Thanks.
Matro
PostPosted: Mon Apr 14, 2008 1:56 am     Reply with quote
setup_timer_2(T2_DIV_BY_1,49,1);
At 20 Mhz, the frequency of PWM will be 100 kHz (timer 2 overflows every 100µs).
Matro.
Guest_18F2431
PostPosted: Mon Apr 14, 2008 2:10 am     Reply with quote
Matro wrote:
setup_timer_2(T2_DIV_BY_1,[color=red]49[/color],1);
Every 10 us? 1/100000Hz = 10us i think.
What the 49 correspond to?
PostPosted: Mon Apr 14, 2008 2:20 am     Reply with quote
The '49', is the count to be used to reset the timer. Since the timer counts from '0', the actual number of counts used, is this number plus 1.
So the timer takes the master oscillator, divided by 4, then divided by 1 (prescaler =1), then by 50.
Gives 100KHz, and as you say 10uSec (I'd suspect just a simple typing error).
Guest_18F2431
PostPosted: Mon Apr 14, 2008 2:30 am     Reply with quote
Ok, i begin to understand.
Where i can find the value 4?
Matro
PostPosted: Mon Apr 14, 2008 2:35 am     Reply with quote
That was a mistake. Of course it is 10µs.
Sorry for that but I see that you correct by yourself. ;-)
Matro.
Matro
PostPosted: Mon Apr 14, 2008 2:36 am     Reply with quote
4 is present in all datasheets. An instruction cycle is done in 4 clock cycles in a PIC.
Matro.
18F2431
PostPosted: Mon Apr 14, 2008 2:37 am     Reply with quote
Okay, governement still hiding facts !
Thank you, i will probably continue asking question here ;)
PostPosted: Mon Apr 14, 2008 2:38 am     Reply with quote
The 'peripheral clock', used by just about everything inside the PIC, is the same rate as the 'instruction clock', Fosc/4. This is in the data sheet. If you look at the diagrams for the timers, and a lot of other stuff, the sources (depending on the ones you look at), will be various external pins or oscillators, and 'Fosc/4'. This is the /4 factor.
18F2431
PostPosted: Mon Apr 14, 2008 3:01 am     Reply with quote
time=get_timer2();
So, with the previously configurated timer, i would generate an overflow at 10 us.
I have to get the value in a variable. But after, how make an "if" with this value.
Example :
if (time==10us)
TMR2IF = 1 //to do an overflow ?
I have problems here. 10us, i cannot put like that.
Will my TMR2IF=1 working? [/code]
