Aurbo
Migration problem |
Posted: Wed Apr 09, 2008 3:20 pm |
Greetings,
By no means an expert,
I was lucky enough to convert a 16F628A code to an 18F4525 without any major issues.. except one. By converting, I replaced the #include <16F628A.h> with #include <18F4525.h> and re-compiled.
The Temp sensor, original ds1820 has been replaced with a newer ds18b20. The timer code runs fine, but the temperature sensor is reading 0, which to me means its not reading, not converting, or just plain broken.
I'm not sure where the error could be, perhaps Pin_A0 is not digital and I've no clue what I need to do to set PIN_A0 to digital to see if that is my error.
Can anyone see a possible culprit in this?
// DIGITAL 24 Hour Clock with Thermometer project
// Compiler : PIC C
// Code originally from Sixca.com
#fuses NOSTVREN,NOWDT,NOMCLR,NOPROTECT,NOBROWNOUT,NOPUT,NOLVP,NOPBADEN,XT
//#fuses NOWDT,XT, NOPUT, PROTECT,NOLVP,NOMCLR,NOLVP // for 628
#include <ds1820.c>
#define DS1307_SDA PIN_A2
#define DS1307_SCL PIN_A3
#use i2c(master, sda=DS1307_SDA, scl=DS1307_SCL)
//ADCON1 = 0b00001111; //configuring analog port to digital
//TRISA = 0b00000001; //PORT A0 as digital i/p
byte CONST MAP1[10]={0xFA,0x30,0xD9,0x79,0X33,0x6B,0xEB,0x38,0xFB,0x7B};
byte CONST MAP2[10]={0xDE,0x18,0xCD,0x5D,0X1B,0x57,0xD7,0x1c,0xDF,0x5F};
byte sec,min,hour;
byte fs_flag;
#define EXP_OUT_LATCH PIN_B7
#define EXP_OUT_CLOCK PIN_B3
#define EXP_OUT_DO PIN_B5
#define EXP_OUT_CLEAR PIN_B6
#define colon PIN_B4
#define DEC PIN_B1
#define INC PIN_B2
#define Tsensor PIN_A0
BYTE buff[9], sensor, n,temp,temp_dec,RES;
BYTE D_SHIFT;
// initial DS1307
void init_DS1307()
output_float(DS1307_SCL);
output_float(DS1307_SDA);
// write data one byte to
// DS1307
void write_DS1307(byte address, BYTE data)
short int status;
i2c_start();
i2c_write(0xd0);
i2c_write(address);
i2c_write(data);
i2c_stop();
i2c_start();
status=i2c_write(0xd0);
while(status==1)
i2c_start();
// read data one byte from DS1307
BYTE read_DS1307(byte address)
BYTE data;
i2c_start();
i2c_write(0xd0);
i2c_write(address);
i2c_start();
i2c_write(0xd1);
data=i2c_read(0);
i2c_stop();
return(data);
// WRITE DATA TO 6B595
void write_expanded_outputs(BYTE *D)
BYTE i;
for(i=1;i<=8;++i)
{ // Clock out bits from the eo array
if ((D & 0x80)==0)
output_low(EXP_OUT_DO);
output_high(EXP_OUT_DO);
D=D<<1;
output_high(EXP_OUT_CLOCK);
output_low(EXP_OUT_CLOCK);
// show temperature
void show_temp()
int8 count;
output_high(colon);
for (count=0;count<8;count++) // blink temperature 8 times
output_low(EXP_OUT_LATCH);
sensor=0; // DS1820 CONNECT TO PIN A0
init_ds1820(sensor);
write_ds1820_one_byte(0xcc, sensor); // skip ROM
write_ds1820_one_byte(0x44, sensor); // perform temperature conversion
while (read_ds1820_one_byte(sensor)==0xff); // wait for conversion complete
write_ds1820_one_byte(0xbe, sensor); // read the result
for (n=0; n<9; n++) // read 9 bytes but, use only one byte
buff[n]=read_ds1820_one_byte(sensor); // read DS1820
temp=buff[0]>>1;
if ((buff[0] & 0x1)==1)
temp_dec=5;
temp_dec=0;
D_SHIFT=0x00;
write_expanded_outputs(D_SHIFT);
D_SHIFT=0xE1; // show 'C
RES=TEMP%10;
D_SHIFT=MAP1[RES];
RES=TEMP/10;
if (RES==0)
D_SHIFT=0x00;
D_SHIFT=MAP1[RES];
output_high(EXP_OUT_LATCH);
for (n=1;n<=4;n++)
D_SHIFT=0x00;
// show time 1
void show_time1()
byte m;
output_low(colon);
min=read_ds1307(1);
hour=read_ds1307(2);
m=min & 0x0F;
D_SHIFT=MAP2[m];
swap(min);
m=min & 0x07;
D_SHIFT=MAP2[m];
m=hour & 0x0F;
D_SHIFT=MAP1[m];
swap(hour);
m=hour & 0x03;
D_SHIFT=MAP1[m];
swap(min);
swap(hour);
// check switch
void check_sw()
byte j;
if (fs_flag!=0)
if (!input(INC))
if (fs_flag==1)
min=read_ds1307(1);
min++;
j=min & 0x0F;
if (j>=0x0A) min=min+0x06;
if (min>=0x60) min=0;
write_ds1307(1,min);
hour++;
j=hour & 0x0F;
if (j>=0x0A) hour=hour+0x06;
if (hour>=0x24) hour=0;
write_ds1307(2,hour);
show_time1();
if (!input(DEC))
if (fs_flag==1)
min=read_ds1307(1);
if (min!=0)
min--;
j=min & 0x0F;
if (j>=0x0A) min=min-0x06;
else min=0x59;
if (hour!=0)
hour--;
j=hour & 0x0F;
if (j>=0x0A) hour=hour-0x06;
else hour=0x23;
show_time1();
// show time
void show_time(byte fs)
byte m;
output_low(colon);
min=read_ds1307(1);
m=min & 0x0F;
D_SHIFT=MAP2[m];
swap(min);
m=min & 0x07;
D_SHIFT=MAP2[m];
m=hour & 0x0F;
D_SHIFT=MAP1[m];
swap(hour);
m=hour & 0x03;
D_SHIFT=MAP1[m];
swap(min);
swap(hour);
check_sw();
check_sw();
check_sw();
check_sw();
check_sw();
//delay_ms(500);
if (fs==0)
output_high(colon);
//delay_ms(500);
if (fs==1)
output_high(colon);
D_SHIFT=0x00;
D_SHIFT=0x00;
m=hour & 0x0F;
D_SHIFT=MAP1[m];
swap(hour);
m=hour & 0x03;
D_SHIFT=MAP1[m];
//delay_ms(500);
output_high(colon);
m=min & 0x0F;
D_SHIFT=MAP2[m];
swap(min);
m=min & 0x07;
D_SHIFT=MAP2[m];
D_SHIFT=0x00;
D_SHIFT=0x00;
//delay_ms(500);
check_sw();
check_sw();
check_sw();
check_sw();
check_sw();
#int_EXT
void EXT_isr()
fs_flag++;
if (fs_flag>=3) fs_flag=0;
// main program start here
byte u;
delay_ms(5);
port_b_pullups(true);
output_low(EXP_OUT_CLEAR);
delay_us(10);
output_high(EXP_OUT_CLEAR);
for(RES=0;RES<80;RES++)
// ADCON1 = {0b00001111}; //configuring analog port to digital
// TRISA = {0b00000001}; //PORT A0 as digital i/p
sensor=1; // DS1820 CONNECT TO PIN A0
init_ds1307();
u=read_ds1307(0);
sec=u & 0x7F;// enable RTC
write_ds1307(0,sec); // set second to 00 and enable clock(bit7=0)
fs_flag=0;
ext_int_edge(H_TO_L); // init interrupt triggering for button press
enable_interrupts(INT_EXT);
while(true)
disable_interrupts(INT_EXT);
if (fs_flag==0)
show_temp();
for (u=0;u<20;u++)
show_time(fs_flag);
} //end of main program |
Posted: Wed Apr 09, 2008 4:14 pm |
Post your compiler version. You can find it at the top of the .LST file
for this program. Look in the project directory for .LST file. |
Aurbo
Posted: Wed Apr 09, 2008 4:56 pm |
CCS PCH C Compiler, Version 4.038, 18306 09-Apr-08 19:09 |
Posted: Wed Apr 09, 2008 6:06 pm |
Quote: | CCS PCH C Compiler, Version 4.038 | This is an old compiler release and not very stable, it might work but no guarantees. Best is to use the old v3.249 or upgrade to a recent version.
Quote: | I'm not sure where the error could be, perhaps Pin_A0 is not digital and I've no clue what I need to do to set PIN_A0 to digital to see if that is my error. | Add the following to the start of your main: Code: | setup_adc_ports( NO_ANALOGS ); |
Code: | #use i2c(master, sda=DS1307_SDA, scl=DS1307_SCL)
void init_DS1307()
| Do not call the output_float() function for the I2C lines. The compiler will take care of all this and now you might interfere with the compiler handling of these lines.
Code: | void write_expanded_outputs(BYTE *D) | Here is a bug: The variable D isn't a pointer and you will get unpredictable results. Get rid of the '*'.
Posted: Wed Apr 09, 2008 6:17 pm |
Quote: | ds1820 has been replaced with a newer ds18b20 |
These are different chips.
From the DS1820 data sheet:
Quote: |
Temperature is read as a 9–bit digital value.
From the DS18B20 data sheet:
Quote: | The resolution of the temperature sensor is user-configurable to 9, 10, 11, or 12 bits. The default resolution at power-up is 12-bit. |
I suggest that you remove the ds1820 from the old board and move it
to the new board. Then your program might work. |
Aurbo
Posted: Wed Apr 09, 2008 6:19 pm |
Thanks for the tips,
My son-in-law's laptop and software, I'll encourage him to go get an upgrade on this software once he returns from his tour. I just tinker with it and keep his emails and anti-virus up to date.
So just remove the * and the entire float routine? |
Posted: Wed Apr 09, 2008 6:27 pm |
Quote: | So just remove the * and the entire float routine? | You posted this while I was editing and PCM Programmer added another issue.
- Remove the *
- Get rid of the init_DS1307 routine.
- Add a call to setup_adc_ports( NO_ANALOGS ) at program start.
- Get the circuit running with the old chip. After that we can help you with modifications for the new chip. |
Aurbo
Posted: Wed Apr 09, 2008 6:36 pm |
I'll go back to the old 16F628A right now,
As for the other stuff, I'll step through each and see what happens
Thanks again for the help.. This Pic stuff is pretty interesting, should have tried it a decade or so ago while I was still surrounded with the young bucks in the dev shop. |
Aurbo
Posted: Wed Apr 09, 2008 7:28 pm |
OK, back on the 16F628A
removed the * and init 1307 routine, nothing worked.
Returned everything to original, and its all back.
timer code is working, the temp sensor is reading 7 degrees, ( not correct)
I've never had a ds1820, I've only got the ds18b20's which would explain why the temp sensor has never worked for me.
I'm not sure how to proceed from here,
Strip out the code for the ds1820 , leaving only the clock.
Then use the correct code and drivers/.h/.c files needed to make it run correctly.
Just because its running, does not mean its running right, and I'll never learn the correct methods of programming these things by sticking to bad code.
Once the clock functions are correct, I can look at bringing in the proper ds18b20 device.
I know enough Basic to be dangerous, but C is compelling.
Does this sound like a better approach than trying to repair this code, most of which is still a mystery to me?
My goal is to have a nice big led clock in the front window of the house by July 3rd, the day my son-in-law return from over there.
I'll keep the "broken" code that runs the clock safely stashed to use in case I cant get this thing running in time.
Thanks again |
Aurbo
Posted: Thu Apr 10, 2008 1:06 pm |
Ok, new day, fresh perspective;
I've removed all the code for the ds1820 sensor, What remains below is currently working and keeping correct time.
What if any changes need be done to this code, before I attempt to introduce the new ds18b20 routines.
*EDIT = Selection/set button is not responding properly on PIN_B0 (fs_flag)? on initial power on the clock flashes :00 to allow minute adjustment, but its not accepting the selection/set button to allow Hours or exit the "check switch routine"
Cheers
// 24 Hour Clock
// Dallas ds1307
// TPIC6B595N
// 2008
#FUSES XT //Crystal osc <= 4mhz
#define RTC_SDA PIN_A2
#define RTC_SCL PIN_A3
#use i2c(master, sda=RTC_SDA, scl=RTC_SCL)
#define DEC PIN_B1
#define INC PIN_B2
BYTE CONST MAP1[10]={0xFA,0x30,0xD9,0x79,0X33,0x6B,0xEB,0x38,0xFB,0x7B};
BYTE CONST MAP2[10]={0xDE,0x18,0xCD,0x5D,0X1B,0x57,0xD7,0x1c,0xDF,0x5F};
BYTE sec,min,hour;
BYTE fs_flag;
BYTE RES;
BYTE D_SHIFT;
// initial DS1307
void init_DS1307()
output_float(RTC_SCL);
output_float(RTC_SDA);
// write data one byte to DS1307
short int status;
i2c_start();
i2c_write(0xd0);
i2c_write(address);
i2c_write(data);
i2c_stop();
i2c_start();
while(status==1)
i2c_start();
BYTE data;
i2c_start();
i2c_write(0xd0);
i2c_write(address);
i2c_start();
i2c_write(0xd1);
data=i2c_read(0);
i2c_stop();
return(data);
void write_expanded_outputs(BYTE D)
BYTE i;
for(i=1;i<=8;++i)
if ((D & 0x80)==0)
D=D<<1;
// show time 1
void show_time1()
byte m;
output_low(colon);
min=read_ds1307(1);
m=min & 0x0F;
D_SHIFT=MAP2[m];
swap(min);
m=min & 0x07;
D_SHIFT=MAP2[m];
m=hour & 0x0F;
D_SHIFT=MAP1[m];
swap(hour);
m=hour & 0x03;
D_SHIFT=MAP1[m];
swap(min);
swap(hour);
// check switch
void check_sw()
byte j;
if (fs_flag!=0)
if (!input(INC))
if (fs_flag==1)
min=read_ds1307(1);
min++;
j=min & 0x0F;
hour++;
j=hour & 0x0F;
show_time1();
if (!input(DEC))
if (fs_flag==1)
min=read_ds1307(1);
if (min!=0)
min--;
j=min & 0x0F;
else min=0x59;
if (hour!=0)
hour--;
j=hour & 0x0F;
else hour=0x23;
show_time1();
// show time
byte m;
output_low(colon);
min=read_ds1307(1);
m=min & 0x0F;
D_SHIFT=MAP2[m];
swap(min);
m=min & 0x07;
D_SHIFT=MAP2[m];
m=hour & 0x0F;
D_SHIFT=MAP1[m];
swap(hour);
m=hour & 0x03;
D_SHIFT=MAP1[m];
swap(min);
swap(hour);
check_sw();
check_sw();
check_sw();
check_sw();
check_sw();
//delay_ms(500);
if (fs==0)
output_high(colon);
if (fs==1)
output_high(colon);
D_SHIFT=0x00;
D_SHIFT=0x00;
m=hour & 0x0F;
D_SHIFT=MAP1[m];
swap(hour);
m=hour & 0x03;
D_SHIFT=MAP1[m];
//delay_ms(500);
output_high(colon);
m=min & 0x0F;
D_SHIFT=MAP2[m];
swap(min);
m=min & 0x07;
D_SHIFT=MAP2[m];
D_SHIFT=0x00;
D_SHIFT=0x00;
//delay_ms(500);
check_sw();
check_sw();
check_sw();
check_sw();
check_sw();
#int_EXT
void EXT_isr()
fs_flag++;
byte u;
delay_ms(5);
delay_us(10);
init_ds1307();
u=read_ds1307(0);
fs_flag=0;
while(true)
if (fs_flag==0)
// show_temp();
for (u=0;u<20;u++)
show_time(fs_flag);
Posted: Thu Apr 10, 2008 2:52 pm |
Quote: | Selection/set button is not responding properly on PIN_B0. |
Look at your posted code. Is there any reference to PIN_B0 anywhere
in the program ? |
Posted: Thu Apr 10, 2008 3:08 pm |
Code: | disable_interrupts(INT_EXT);
if (fs_flag==0)
// show_temp();
| You are disabling the code here in a wrong way. What remains is: Code: | disable_interrupts(INT_EXT);
if (fs_flag==0)
enable_interrupts(INT_EXT); | After the first button press fs_flag will be unequal to zero, interrupts get never enabled again and the switch stops responding...
I had a look at the file ds1820.c and I'm not happy with what I see there, for example it contains hard coded addresses which explains why your code didn't work on the PIC18. I will come back to this later. |
Posted: Thu Apr 10, 2008 3:13 pm |
PCM programmer wrote: | Quote: | Selection/set button is not responding properly on PIN_B0. |
in the program ? | It's there, INT_EXT.
I've seen better styled programs but as the original poster says, it is working (kind of). |
Posted: Thu Apr 10, 2008 3:28 pm |
OK, sorry. I blew one.
Thanks for catching it. ![Very Happy](images/smiles/icon_biggrin.gif) |
Aurbo
Posted: Thu Apr 10, 2008 5:01 pm |
Thanks.. I didnt see that last remaining bit of temperature code.
OK, so by removing the three lines of // disabled code, it will allow the enable _ interrupts again? or am I missing another enabler?
On a similar note, I'm using a JDM Enhanced programmer to write to the chip, There MUST be an easier way than to swap it in and out with the old chip pliers.
Will an ICD or other device aid in all of this? suggestions?
Cheers |
