Error using strcmp()
boham
PostPosted: Wed Apr 09, 2008 7:34 am     Reply with quote
I am having an error whenever I use the strcmp function. Any help would be appreciated.
#include <18F4520.h>
#fuses   HS,NOLVP, NOWDT
#use   delay(clock = 20000000)
#use   rs232 (baud=9600, xmit=PIN_C6, rcv=PIN_C7)
#include <string.h>   // for strcmp()
#define PUSH_BUTTON   PIN_A4
void wait_for_one_press(){
   while(input(PUSH_BUTTON));
   delay_ms(100);   // switch de-bounce
   while(!input(PUSH_BUTTON));
void BR_get_string(char *s){   //blue radio get string
   char   input;
   input = getc();   // <CR>
   getc();   // <LF>
   input = getc();      // message<CR>   NOTE: <CR> is not put into the array.
   input = getc();;   // <LF>
void main(){
   char   myStr[25];   // make this only as big as the longest message plus one for the null character '\0'
      wait_for_one_press();
      printf("ATSW25,1,1,0,0\r");
      BR_get_string(myStr);
      if (strcmp(myStr, &"OK"))
         continue;
      printf("ATDM,00A096141292,1101\r");
      //BR_get_string(myStr);
      //if (strcmp(myStr, &"CONNECT,00A096141292"))
      //   continue;
      //printf("+++\r");
      //if (strcmp(myStr, &"OK"))
      //   continue;
      //printf("ATEDSCO\r\n");
At the line
and the other places in the comments above, I get the error:
Expecting an identifier
meereck
PostPosted: Wed Apr 09, 2008 7:47 am     Reply with quote
hi, you need to have a string in RAM if you want to use STRCMP function on it.
I usually do smthg like this:
char tempbuf[10];
sprintf(tempbuf,"OK");
if(strcmp(receivecharacterbuffer,tempbuf)!=0) printf("different");
see this to understand what strcmp returns : http://www.elook.org/programming/c/strcmp.html
boham
PostPosted: Wed Apr 09, 2008 7:53 am     Reply with quote
No errors! Thank you very much. I'll see later on how it runs in the PIC
Matro
PostPosted: Wed Apr 09, 2008 8:01 am     Reply with quote
Another way to make it work...
I take the following "line" as an example but all similar lines have the same problem :
First, to use constant strings, you need to add in your code :
#device PASS_STRINGS = IN_RAM
And then the '&' shall not be present :
(strcmp(myStr, "OK"))
Now it should work.
Matro.
boham
PostPosted: Wed Apr 09, 2008 11:02 am     Reply with quote
Allrighty... The code looks just to me but I think the direction I am going is not right.
The radio I am controling receives a command and replies with an OK status if everything is good.
I can command this thing all day long but it seems that I cannot check for that OK reply.
Sent : ATSW25,1,1,0,0<cr> // Set ConnectMode Master & data mode
Reply:<cr_lf>OK<cr_lf>
Is what I am trying to accomplish.
The above code works if I do not try to invoke the
command.
What I want to do is take that reply and continue if the reply is
<cr_lf>OK<cr_lf>
and not continue otherwise.
meereck
PostPosted: Wed Apr 09, 2008 11:21 am     Reply with quote
It probably doesnt work with v3 compilers, does it?
PostPosted: Wed Apr 09, 2008 11:40 am     Reply with quote
That's right. It requires vs. 4 to work.
In vs. 3, you have to copy the string to a RAM array with explicit code.
ftrax
PostPosted: Fri May 08, 2015 5:02 am     Reply with quote
thank you very much Matro, I've been looking for any instruction like this for a long time, thank you very much !!
Very Happy Very Happy
