In interrupt routine,
On first rising edge I have reset the timer3 . and on next rising edge I have taken CCP2 register value. So this will be my timer counter(16 bit) between two rising edge.
From the above details we can calculate timer3 frequency = 625000 Hz.
#define FREQ_CONST 625000L
1) so Frequency of subjected waveform = (unsigned char)(FREQ_CONST / timer counter )
Is this above method is OK ? any betterment using CCP2 module only.?
2) When power goes off , the signal at micro ccp2 pin will be at low state. Supposing that just before power gets off micro has detected a rising edge and reset the timer3 .Now micro will not get a rising edge until power comes .So I can’t update frequency(let’s say in last calculation frequency was 49 Hz) .But I have to detect the frequency .
To solve this ……
I have created a 10ms time base using timer0.At every 10 ms I will increment a counter
Void f1_10ms(){
Zxcntr++;
I will reset that counter whenever there is rising edge found.In case of power goes off this counter will not reset .So I will check 5 such count i.e 50 ms and conclude that frequency is zero and reset that counter.
Is this method correct and reliable ? Could anybody suggest me for any better method ?
Regards,
Arup
Posted: Tue Apr 08, 2008 11:12 pm
There are several threads on using the CCP to find the frequency.
Just search for:
