issue with ADC
Goto page 1, 2  Next
sliders_alpha
issue with ADC
PostPosted: Fri Apr 04, 2008 10:02 am     Reply with quote
plop,
i've got troube with the ADC.
i need :
1 ADC input
1 digital input
2 digital output
1 digital open-drain output.
so i wanted to do it like this :
#include <16F876.h>
#device ADC = 10
#use delay(clock = 4000000)
void main(){
set_tris_A(0x03);
output_A(0x00);
setup_adc_ports(RA0_ANALOG);
short adcvalue;
      while(1){
                   my code here
with this, only PIN_A4,PIN_A1 and pin_A2 are working, I can't put anything on PIN_A3 and my ADC input isn't working.
do you know why?
ps : i'm reading the ADC like this : value = readadc();
thanks
yup, i know, i don't speak english very well
CCS V4.057
Matro
PostPosted: Fri Apr 04, 2008 10:52 am     Reply with quote
set_tris_A(0x03);
This line is unuseful since you don't use fast_io or fixed_io
With the piece of code that you posted, there is no use of ADC so hard to say what is bad...
Matro.
sliders_alpha
PostPosted: Fri Apr 04, 2008 11:04 am     Reply with quote
well if i've correctly understand.
i need to put :
#use fast_io
in my code to make it work, also, you want to see the full code :
#include <16F876.h>
#device ADC=10
long adcvalue;
short read;
set_tris_A(0x03);
output_A(0x00);
set_adc_channel(0);
while(1){
adcvalue = read_adc();
if (adcvalue < 799){
output_BIT(PIN_A4, 1);
delay_us(800);
output_BIT(PIN_A4, 0);
delay_us(200);
output_BIT(PIN_A5, 1);
else {
output_BIT(PIN_A5, 0);
read = input(PIN_A1);
if (read == 1){
output_BIT(PIN_A2, 1);
output_BIT(PIN_A2, 0);
output_BIT(PIN_A3, 1);
CCS V4.057
Matro
PostPosted: Fri Apr 04, 2008 11:12 am     Reply with quote
Simpler than using fast_io, as a first step you can just remove these 2 lines :
set_tris_B(0x03);
output_B(0x00);
So now the code is here, what is exactly the problem?
Does the code is locked in the "read_adc()"?
Or the read value isn't the one you are waiting for?
Matro.
sliders_alpha
PostPosted: Fri Apr 04, 2008 11:24 am     Reply with quote
nope
read_adc always return a value<799 wich is not normal.
and pin A3 is always at low state.
if i'm usign A0 as an ADC and port B for my digital input/output everything works. but i can only have an open-drain output on port A
CCS V4.057
Matro
PostPosted: Fri Apr 04, 2008 11:34 am     Reply with quote
In your 2nd post, all possible analog inputs are selected as analog when in your 1st post only AN0 is selected.
Which of both are you using?
Matro
sliders_alpha
PostPosted: Fri Apr 04, 2008 11:44 am     Reply with quote
sorry,
(edited)
CCS V4.057
w2drz
Looks to be same issue addressed in the post listed below
PostPosted: Fri Apr 04, 2008 3:01 pm     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=34287
tom
PostPosted: Fri Apr 04, 2008 3:36 pm     Reply with quote
Note also (not mentioned yet), that a 'short', cannot hold a 10bit adc value. The register used to receive the ADC value, _must_ be declared as a 'long'.
sliders_alpha
PostPosted: Fri Apr 04, 2008 4:17 pm     Reply with quote
@tetelma, well, i'm using a long type.
and i find a solution, if I replace :
set_tris_A(0x03);
output_A(0x00);
by
output_float(PIN_A1);
output_drive(PIN_A2);
output_drive(PIN_A3);
output_drive(PIN_A4);
output_drive(PIN_A5);
but why? i mean, i don't see any error in my first code
CCS V4.057
Matro
PostPosted: Sat Apr 05, 2008 4:10 am     Reply with quote
Because you don't use fast_io or fixed _io the compiler will automatically set the tris for you and so all port A pins will be outputs. What isn't compatible with ADC.
That's why I asked that you remove them. ;-)
Matro.
PostPosted: Sat Apr 05, 2008 4:56 am     Reply with quote
The 12th line in your original posted code (which can't work, because type declarations in C, _must_ be in front of code in any section), says 'short adcvalue;', which is what worried me...
sliders_alpha
PostPosted: Mon Apr 07, 2008 12:55 pm     Reply with quote
ha ok, but i don't understand how to use fast_io or fixed_io.
i juste need to write #use fast_io in my code and then i'll be able to use :
set_tris_A(0x03);
output_A(0x00);
@ Ttelmah : my bad ;)
CCS V4.057
Matro
PostPosted: Mon Apr 07, 2008 1:01 pm     Reply with quote
#use fast_io(port_a)
is an example for using fast_io for the port A (and only this one).
Matro.
Matro
PostPosted: Mon Apr 07, 2008 1:05 pm     Reply with quote
Have a look at the reference manual or in PCW help (if you own it).
ccsinfo . com / downloads / CReferenceManual . pdf
-remove the spaces in the link. ;-)
Matro
Goto page 1, 2  Next
Page 1 of 2
