gets help!!!
sohailkhanonline
View user's profile Send private message Visit poster's website Yahoo Messenger MSN Messenger
gets help!!!
PostPosted: Thu Apr 03, 2008 1:33 am     Reply with quote
#include <18F452.h>
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,stream=App,bits=8)
#use rs232(baud=9600,parity=N,xmit=PIN_B1,stream=PC,bits=8)
i am using int_RDA for stream App but i am not successful to use it for stream PC.
if interrupt is only allowed for hardware UART. How can i get string from other stream....
Matro
PostPosted: Thu Apr 03, 2008 1:39 am     Reply with quote
#int_RDA is an interrupt trigerred when receiving a byte.
Your PC stream hasn't a receive PIN.
So I can't understand your question.
Matro.
PostPosted: Thu Apr 03, 2008 2:41 am     Reply with quote
i am sorry i forget to mention
#use rs232(baud=9600,parity=N,xmit=PIN_B1,rcv=PIN_B4,stream=PC,bits=8)
Matro
PostPosted: Thu Apr 03, 2008 3:05 am     Reply with quote
The fact is that an interrupt can't be generated if you use a "software" serial communication engine.
You have to poll it.
But personally I would have use the B4 pin for TX and B1 for RX. Because B1 is an external interrupt pin, you should have activated the corresponding interrupt and use it to detect the start condition of a new byte.
Matro.
Audi80
PostPosted: Thu Apr 03, 2008 10:27 am     Reply with quote
Hi there i would suggest a usage of a pic with 2 uarts if that´s what you want do you want to interrupt is anything comes from the both serial ports?? if so you can use a 18f8723 that has 2 uarts, that´s what i use for most projects and the you could do something like this:
#include <18F8722.h>
#fuses INTRC,NOPROTECT,NOWDT
#DEVICE HIGH_INTS=TRUE
#use delay(clock=32000000)
#use rs232(baud=9600, xmit=PIN_G1,rcv=PIN_G2,ERRORS,UART2,STREAM=COM2,BRGH1OK)
#use rs232(baud=9600, xmit=PIN_C6,rcv=PIN_C7,ERRORS,UART1,STREAM=COM1,BRGH1OK)
#INT_RDA2
   void something2(){
      fputc(fgetc(COM2),COM2);
#INT_RDA
   void something1(){
      fputc(fgetc(COM1),COM1);
   setup_oscillator(OSC_32MHZ);
   enable_interrupts(INT_RDA);
   enable_interrupts(INT_RDA2);
   for(;;){}
Hope it helps...
PostPosted: Thu Apr 03, 2008 10:39 pm     Reply with quote
thank you!!
