problem with "get_string" in #int_rda
umka
PostPosted: Tue Apr 01, 2008 4:31 pm     Reply with quote
I am trying to receive a string through the serial port that only updates when new data is sent.
the string will be sent at random time intervals so thought i should use #int_rda but once the string has been sent the micro does not leave the interrupt.
is there also a way to clear the String in "array" or does one have to use a for statement?
the high/low pin d2 is an LED to see if the code is looping.
#include <16F877a.H>
#device icd=true
#use delay(clock = 4000000)
#use rs232(baud = 19200, xmit=PIN_C6, rcv = PIN_C7, ERRORS)
#include <input.c>
#include <Flex_LCD420.c>
#define BUF_SIZE  25
char array[BUF_SIZE];
#int_rda
void Serial_isr()
      get_string(array, BUF_SIZE);  // Get string from serial port
   enable_interrupts(int_rda);
   lcd_init();
   printf(lcd_putc, "\f");
               output_high(pin_d2);
               printf(lcd_putc, "\f\r%s", array);           // Display string recieved
               output_low(pin_d2);
PostPosted: Tue Apr 01, 2008 7:07 pm     Reply with quote
Try this. This program combines the Ex_Sisr.c with the get_string()
function. Instead of calling getc(), get_string() now calls bgetc(), so
that it gets characters from the receive buffer that is filled byint_rda.
Example of output:
Enter a string of text: hello world
You typed: hello world
#include <16F877.H>
#define BUFFER_SIZE 32
BYTE buffer[BUFFER_SIZE];
BYTE next_in = 0;
BYTE next_out = 0;
#int_rda
void serial_isr() {
   int t;
   buffer[next_in]=getc();
   t=next_in;
   if(next_in==next_out)
     next_in=t;           // Buffer full !!
BYTE bgetc() {
   BYTE c;
   while(!bkbhit) ;
   c=buffer[next_out];
   return(c);
void my_get_string(char* s, unsigned int8 max) {
   unsigned int8 len;
   char c;
   --max;
   len=0;
   do {
     //c=getc();  // Commented out.
       c = bgetc();   // Call bgetc() instead of getc()
       if(c==8) {  // Backspace
        if(len>0) {
          len--;
          putc(c);
          putc(' ');
          putc(c);
     } else if ((c>=' ')&&(c<='~'))
       if(len<=max) {
         s[len++]=c;
         putc(c);
   } while(c!=13);
   s[len]=0;
#define STRING_SIZE 40
char input_str[STRING_SIZE];
enable_interrupts(global);
   printf("Enter a string of text: ");
   my_get_string(input_str, STRING_SIZE-1);
   printf("\n\rYou typed: %s \n\r\n\r", input_str);
umka
PostPosted: Tue Apr 01, 2008 9:12 pm     Reply with quote
Thanks PCM
but i ran that exact code you posted but it doesn't seem to work. Using the CCS serial terminal it say"Enter a string of text:" then i enter a "michael" and it echo's "michael" into the serial window but then doesn't do anything else. if i continue to send more data it i presumes fills the buffer and then stops echoing to the port and totally stops working.
PostPosted: Wed Apr 02, 2008 3:27 am     Reply with quote
You do need to hit the carriage return key, to say that the string has finished.
umka
PostPosted: Wed Apr 02, 2008 1:23 pm     Reply with quote
what is the carriage return key?
once the string has been typed i push send and thats it. what else am i supposed to do?
PostPosted: Wed Apr 02, 2008 2:04 pm     Reply with quote
Normally, you just type the text into HyperTerminal or some other
terminal program, and then press the Enter key on your PC keyboard.
Here is a screenshot of HyperTerminal. It comes with Windows:
http://www.brothersoft.com/internet/miscellaneous/screenshots/hyperterminal-private-edition_5661.html
PostPosted: Wed Apr 02, 2008 2:15 pm     Reply with quote
I'm so glad we have internet these days. Now the smart people will surf to the Google website and find the answers much quicker there than they would get an answer in a forum.
How does the program know the end of the string is reached? You need to send a special character here, the 'Carriage Return' code (ASCII value 13, abbreviated CR, generated by the enter/return key on your keyboard). Check also your CCS manual in the chapter on the gets() function.
umka
PostPosted: Wed Apr 02, 2008 3:18 pm     Reply with quote
thats what i have been doing. As stated above i have been using the terminal that comes with the ccs ide.
PostPosted: Wed Apr 02, 2008 4:15 pm     Reply with quote
The 'send' button in SIOW.exe doesn't send a carriage return (0D).
It just transmits the hex bytes that you have typed into the lower box.
Instead of doing that, just click on the black area and type your text in, and press the Enter key on your PC.
Or use hyperterminal.
umka
PostPosted: Wed Apr 02, 2008 4:30 pm     Reply with quote
thanks yet again PCM works a treat
PostPosted: Sun Apr 13, 2008 9:09 am     Reply with quote
its working good in the hyperterminal.. thanks alot PCM... do u mind explain more about the working of the program? because i'm still a beginner in CCS and i'm trying to learn more to complete my project...
welldone!
