StudentInNeeded Guest
Rotating text with PIC16F877 |
Posted: Mon Mar 31, 2008 2:04 pm |
I need some help, I'm doing an LED display controlled by a PIC16F877A. All my columns are linked together and all my rows too, so I can control independently each LED. Now, I have 28 columns by 7 rows, and I can send 1 letter, that mean 6 columns by 7 rows. But when I upgrade my two-dimensional table variable to 28(columns) and that I compile, CCS me returns an error "Data item too big".
1 Letter declaration: (Working)
int Table[7][6]={0,1,1,1,0,0,
1,0,0,0,1,0,
1,0,0,0,0,0,
1,0,1,1,1,0,
1,0,0,0,1,0,
1,0,0,0,1,0,
0,1,1,1,1,0}; |
28 columns declaration: (Error: Data item too big)
int rom Table[7][28]={
0,1,1,1,0,0,0,1,1,1,0,0,0,1,1,1,0,0,1,0,0,0,0,0,0,1,0,0,
1,0,0,0,1,0,1,0,0,0,1,0,1,0,0,0,1,0,1,0,0,0,0,0,0,1,0,0,
1,0,0,0,0,0,1,0,0,0,1,0,1,0,0,0,1,0,1,0,0,0,0,0,0,1,0,0,
1,0,0,0,1,0,1,0,0,0,1,0,1,0,0,0,1,0,1,0,0,0,0,0,0,0,0,0,
0,1,1,1,0,0,0,1,1,1,0,0,0,1,1,1,0,0,1,1,1,1,1,0,0,1,0,0}; |
I have also added the "rom" option because it was too big for the RAM and I use one table because I need to rotate all columns one by one, to create a rotation.
So anyone can help me or have an good idea,
just share it, it would be appreciated.
Alex |
Posted: Mon Mar 31, 2008 2:36 pm |
Do you need to use a byte for each led ? Why not use a bit ?
Then you can use 1/8 of the RAM for the table.
For example, look at the character font tables in this file.
They pack each character into 5 bytes.
Quote: | c:\Program Files\picc\Drivers\glcd.c |
Spatofy
Posted: Wed Apr 02, 2008 6:51 am |
I can't use that glcd.c because I'm doing my own display with LED. It's a matrix of 7x28 and I'm able to send a entire row of 28 at the same time, so I did a refresh procedure to show every row a little time to display a full letter. I need to use a bit for every LED. |
Posted: Wed Apr 02, 2008 9:09 am |
Since your entire data consists of 1's and 0's, you can certainly pack
the data into bytes and then unpack it before you display it. Packing
data into bytes is a standard technique used by embedded programmers
to conserve ROM space. The data is compiled in packed format, and
then you need to write a routine to unpack it at runtime.
Look at the many character generators for LCD that are available on
the net. They graphically show how the packing is done:
http://www.keokitrask.com/EDL/LCDCharacterGenerator.htm
More explanation:
http://www.rentron.com/Myke2.htm |
kamputty Guest
Posted: Wed Apr 02, 2008 2:30 pm |
Hi all!
Look at the OLED example I have in the software area for PIC...it has the 5x7 fonts (thanks to my daughter's handy work) that does it using bits...might help, might not!
~Kam (^8* |
kamputty Guest
Posted: Wed Apr 02, 2008 2:56 pm |
While I was thinking about it...here is the font part of the code...
int8 fonts[80][5]=
{ // 0
0b00111110,
0b01010001,
0b01001001,
0b01000101,
0b00111110
{ // 1
0b00000000,
0b01000010,
0b01111111,
0b01000000,
0b00000000
{ // 2
0b01000010,
0b01100001,
0b01010001,
0b01001001,
0b01000110
{ // 3
0b00100010,
0b01000001,
0b01001001,
0b01001001,
0b00110110
{ // 4
0b00011000,
0b00010100,
0b00010010,
0b01111111,
0b00010000
{ // 5
0b00100111,
0b01000101,
0b01000101,
0b01000101,
0b00111001
{ // 6
0b00111100,
0b01001010,
0b01001001,
0b01001001,
0b00110000
{ // 7
0b00000001,
0b01110001,
0b00001001,
0b00000101,
0b00000011
{ // 8
0b00110110,
0b01001001,
0b01001001,
0b01001001,
0b00110110
{ // 9
0b00000110,
0b01001001,
0b01001001,
0b01001001,
0b00111110
0b00000000,
0b00000000,
0b01011111,
0b00000000,
0b00000000
and so on.
Each character is only 5 bytes...
~Kam (^8* |
Posted: Sun May 18, 2008 12:00 pm |
Finally, i just change my 16f877 for an 18f452, same pinout but way more memory... |
