ferkar
| has portb.3 a special condition? |
Posted: Mon Feb 11, 2008 7:47 am |
hi everybody:)
i would like to ask you a simple question. my 16f877 and pc communicate over rs232 channel. i made a visual basic interface to command to pic. when i send the data,that is 15, 3 leds are turned on while the last one , the msb in nibble , dis not turn on.
i was wondering that is portb.3 need for a pull-up resistor or something like that to give an output?
please help about this...
bye |
Posted: Mon Feb 11, 2008 7:59 am |
From note 3 on Table 3-3 of the PIC16F87x datasheet: | Quote: | 3: Low Voltage ICSP Programming (LVP) is enabled by default, which disables the RB3 I/O function. LVP
must be disabled to enable RB3 as an I/O pin and allow maximum compatibility to the other 28-pin and
40-pin mid-range devices. | Solution: Add #fuse NOLVP to your program. |
ferkar
| thanks for answer |
Posted: Mon Feb 11, 2008 10:07 am |
| i ll try it .. |
ferkar
| thanks indeed... |
Posted: Wed Apr 02, 2008 7:59 am |
the problem was solved ...
thanks |
Posted: Wed Apr 02, 2008 8:31 am |
This is in the CCS FAQ. Bookmark this page:
http://www.ccsinfo.com/faq.php
It's in this section:
| Quote: |
Input/Output
Why isn't PortB, pin 3, working?
rnielsen
Posted: Wed Apr 02, 2008 12:41 pm |
One problem is that many people attempt to 'dive' into writing code without fully reading all of the documentation. I, myself, am guilty of this from time-to-time. I really dislike reading and have a tendancy to realize that I need to read the various spec. sheets fully before I attempt to use new parts.
It's an unfortunate part of lazy human nature.
Ronald |
