sirisopa
TLC2543 Help me please !! ( TLC2543 Hi-tech C to CCSC Code) |
Posted: Wed Apr 02, 2008 3:43 am |
#include <pic.h>
Freely distributable in this original form.
(c) Feb 2000 Shane Tolmie
(c) KeyGhost, now you can record keystrokes on PC with tiny device
Any questions or comments? shane@keyghost.com
Updates to FAQ available from http://www.keyghost.com/htpic
Routines to setup and use the TLC2543 serial 11channel 12bit a/d converter.
For Hi-Tech C v7.85, on a generic PIC micro.
Tested with PIC16F84, PIC12CE674, and PIC16F876 all @ 4Mhz, should work at 16Mhz
Code status: tested and works beautifully.
- the current channel is set by the previous channel supplied
- initially two calls must be made to ad_setgetchannel(), or use slower ad_getchannel(x)
Sample C:
ad_setup(); //sets up port directions
garbage=ad_setgetchannel(0); //sets up current channel to zero, garbage returned
data=ad_setgetchannel(1); //data now has channel 0. Channel for next call is 1
data=ad_setgetchannel(2); //data now has channel 1. Channel for next call is 2
alternatively, use the slower, but more intuitive
ad_getchannel(x). //this uses two calls to return data at channel x.
WARNING: these chips are static sensitive - I had two cease to work on me for some reason.
#define io_clk RB0 //clock on port B bit 7
#define io_clk_dir TRISB0 //clock on port B bit 7
#define ad_data_in RB1
#define ad_data_in_dir TRISB1
#define ad_data_out RB2 //data on port A bit 1
#define ad_data_out_dir TRISB2 //data on port A bit 1
#define ad_cs RB3
#define ad_cs_dir TRISB3
#define port_out 0
#define port_in 1
//call this once to set it up
void ad_setup()
//these in/outs are a bit confusing - its from the TLC2543's perspective
ad_data_in_dir = port_out;
ad_data_out_dir = port_in;
io_clk_dir = port_out;
ad_cs_dir = port_out;
unsigned int ad_setgetchannel(unsigned char channel)
signed char i;
unsigned int data = 0x0;
unsigned int ch_config;
ch_config = channel<<8;
io_clk = 0; //ensure clock is low
ad_cs = 0;
for(i=11; i>=0; i--)
ad_data_in = ((ch_config>>i) & 0x01); //bit to send
data <<= 1; //read the next bit
data |= ad_data_out;
io_clk = 1; //ensure clock is high
ad_cs = 1;
return data;
//recommended routine to call, its only a little slower
unsigned int ad_getchannel(unsigned char channel)
unsigned int dummy;
// call it twice to get and set the channel
dummy=ad_setgetchannel(channel); //get garbage channel, but set next one
dummy=ad_setgetchannel(channel); //get current channel
return dummy;
sirisopa
Posted: Wed Apr 02, 2008 3:45 am |
#include <pic.h>
Sample C:
#define ad_cs RB3
#define port_out 0
#define port_in 1
void ad_setup()
signed char i;
ad_cs = 0;
ad_cs = 1;
return data;
unsigned int dummy;
return dummy;
best regard
wichan |
