Flex_lcd question... |
Posted: Mon Mar 31, 2008 12:16 pm |
I'm using the flex_lcd4x20.c driver in a project. Periodically, I need to clear the LCD of all characters. Is calling the lcd_init function the best way to do this, or is there another, better way?
Dave |
Posted: Mon Mar 31, 2008 12:44 pm |
The function interface is the same as for the CCS LCD drivers.
The following is from the start of the CCS LCD420.c driver file.
It lists the available commands:
// lcd_putc(c) Will display c on the next position of the LCD.
// The following have special meaning:
// \f Clear display
// \n Go to start of second line
// \b Move back one position
Use this to clear the screen:
meereck
Posted: Mon Mar 31, 2008 3:02 pm |
is there any simple way how to clear one row only? Or do I have to write a subroutine for that?
cheers Meereck |
Posted: Mon Mar 31, 2008 3:12 pm |
Use lcd_gotoxy() to set the cursor to the start of the desired row,
and then use a printf() statement to fill the row with spaces. |
meereck
Posted: Mon Mar 31, 2008 3:15 pm |
PCM programmer wrote: | Use lcd_gotoxy() to set the cursor to the start of the desired row,
Right, that is the subroutine I was thinking of. Pity, there is no "\smthng" command for it.
Thank you for an instant reply. |
