HI there-
In the data sheet for the PIC18F452, it lists pin C3 as SCL for the serial clock in/out for i2c mode, it also lists pin C4 as i2c Data I/O.
Do I have to use these pins for i2C communications? I have inherited a board that uses pins E1 and E2, both listed among other things, as digital IO.
Is there a way I can make this work?
The chip that I will be talking to is 24LC256/ 512.
Thanks!
N_N
Posted: Sat Mar 29, 2008 2:39 pm
Just specify PIN_E1 and PIN_E2 in the #use i2c() statement.
The compiler will create software i2c code for those pins.
It will work perfectly well.
Make sure your board has pull-up resistors on SDA and SCL.
