Hardware SPI in 18F2620 ?
custom_elect
PostPosted: Fri Mar 28, 2008 3:33 pm     Reply with quote
Im just moving some working code from 16F877A PCM C 4.06
to:
18F2620 using PCH 4.069
It complains that:
#use spi (SPI1, MASTER)
is "Option invalid Not valid for H/W"
Yet 18F2620 has the same master capable MSSP like 16F877A
Anyone know why?
PostPosted: Fri Mar 28, 2008 3:58 pm     Reply with quote
The #use spi() statement defaults to using "LSB_FIRST". But the
hardware SPI module uses MSB first. So to avoid getting this error
message, you have to put in the MSB_FIRST parameter in the #use spi
statement, when you use the hardware SPI module. Ideally, CCS
should fix this. It should default to MSB first.
Also, it wouldn't hurt if you specify a few more of the parameters
so that they aren't left as some unknown default value. Example:
MODE=0, MSB_FIRST, BITS=8, BAUD=250000
Make sure that the baud rate is actually one that can be achieved
by the hardware.
