Problem using the external interrupt (Rb0) with a PIC16F877
ZeroF877A
PostPosted: Thu Mar 27, 2008 11:09 am     Reply with quote
Hello everyone.
I'm working with a 16F877 using the Tmr1 and Rb0 interrupts. The Tmr1 interrupt works well all the time. However, the external interrupt only works once.
Here's the code for the interrupt
#include "C:\Micro C\Complex test\complex.h"
#include <lcdlib.c>
#include <kbdlib.c>
int starter, i, weight, j;
char keypress, keylcd1, keylcd2, keylcd3, hour1, hour2, min1, min2;
#int_EXT
void EXT_isr()
   starter = true;
#int_timer1
void TIMER1_isr()
   i=++i;
   if(i==2){
   min2=++min2;
   if(min2==':')
      min1=++min1;
      min2='0';
   if(min1=='6')
      min1='0';
      hour2=++hour2;
   if(hour2=='3'&&hour1=='1')
      hour1='0';
      hour2='1';
   i=0;
   lcd_init();
   kbd_init();
   port_b_pullups(true);
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256);
   setup_timer_1(T1_DISABLED);
   enable_interrupts(int_ext);
   enable_interrupts(int_timer1);
   enable_interrupts(global);
   //USER CODE
   min2='0';
   min1='0';
   hour2='0';
   hour1='1';
   setup_timer_1 ( T1_INTERNAL | T1_DIV_BY_8 );
   i=0;
   do{
   while(starter != true){
      lcd_putc('\f');
      lcd_putc(hour1);
      lcd_putc(hour2);
      lcd_putc(':');
      lcd_putc(min1);
      lcd_putc(min2);
      if((hour1=='1'&&hour2=='2')||hour1=='0')
      lcd_putc(" am\n");
      lcd_putc(" pm\n");
      lcd_putc("Sistema Activo");
      delay_ms(250);
      if(hour1=='0'&&hour2=='4')
      disable_interrupts(GLOBAL);
      lcd_putc("\fJornada\n");
      lcd_putc("Finalizada");
      do{
      }while(true);
   clear_interrupt(int_ext);
   starter = 0;
   lcd_putc("\fBienvenido...\n");
   delay_ms(3000);
   lcd_putc("Espere");
   delay_ms(250);
   lcd_putc('.');
   delay_ms(250);
   lcd_putc('.');
   delay_ms(250);
   lcd_putc('.');
   setup_adc_ports(RA0_ANALOG);
   set_adc_channel(0);
   weight = read_adc();
   if(weight<75)
   lcd_putc("\fTipo\n");
   lcd_putc("Liviano");
   delay_ms(2000);
   lcd_putc("\fCodigo de\n");
   lcd_putc("Confirmacion:");
   lcd_putc("\f350\n");
   if(weight>=75&&weight<=150)
   lcd_putc("Pesado");
   delay_ms(2000);
   lcd_putc("\f658\n");
if(weight>=150)
   lcd_putc("Extra Pesado");
   delay_ms(2000);
   lcd_putc("\f999\n");
   do{
   lcd_gotoxy(1,2);
   for(j=0;j<=2;++j)
      do{
      keypress=kbd_getc();
      }while(keypress==0);
      lcd_putc(keypress);
   keylcd1=lcd_getc(1,2);
   keylcd2=lcd_getc(2,2);
   keylcd3=lcd_getc(3,2);
   if(keylcd1!=lcd_getc(1,1)||keylcd2!=lcd_getc(2,1)||keylcd3!=lcd_getc(3,1))
   lcd_gotoxy(1,2);
   lcd_putc("Erroneo");
   delay_ms(1500);
   lcd_gotoxy(1,2);
   lcd_putc("       ");
   lcd_gotoxy(1,2);
   lcd_gotoxy(1,2);
   lcd_putc("Confirmado");
   delay_ms(1500);
   }while(keylcd1!=lcd_getc(1,1)||keylcd2!=lcd_getc(2,1)||keylcd3!=lcd_getc(3,1));
   lcd_putc("\fBuen viaje");
   delay_ms(2000);
   lcd_putc('\f');
   }while(hour1!='0'&&hour2<='4');
And here's the .h:
#include <16F877.h>
#device adc=8
#FUSES XT                       //Crystal osc <= 4mhz
#FUSES PUT                      //Power Up Timer
As you can see, the large piece of code will repeat as long as "starter" is false. The only way to make "starter" true is by pressing a switch on Rb0, thus triggering the interrupt. Once that is done, the program moves forward until a point where it goes back to wait until Rb0 is pressed again.
Now here's the deal. It works wonderfully but only once. Once the program returns to "while(starter != true)", even if you hit the button with a hammer, it won't trigger the interrupt again...
So, what am I missing in the code? Thanks in advice.
PostPosted: Thu Mar 27, 2008 11:19 am     Reply with quote
How can it _ever_ return to the 'while(starter != true)'?.
It'll never go past the:
      do{
      }while(true);
This is a 'forever' loop. it'll never exit, so the code will never go back and wait for 'starter'again....
ZeroF877A
PostPosted: Thu Mar 27, 2008 11:24 am     Reply with quote
do{
}while(true);
That forever loop is intended. It'll only happen IF(hour1=='0'&&hour2=='4'). Which doesn't happen yet. And I've tested that part, it works perfectly fine, it's supposed to be an endless loop when the "timer" reaches 04. Thanks for the help anyway =D
EDIT: It DOES return to the 'while(starter != true)', since it's a LCD refresh loop (I'm emulating a 'real time' clock [1 minute per second] using tmr1). And after the rest of the code is executed it returns to showing the 'current time'. It refreshes properly and all. Goes ahead and displays "Jornada Finalizada" via LCD AND THEN it goes into the infinite loop, which is intended to be sort of the end of the program.
Matro
PostPosted: Thu Mar 27, 2008 12:06 pm     Reply with quote
Ttelmah is right!
This loop
do{
}while(true);
is endless.
So the application will stay here ... and that's all.
Matro
Matro
PostPosted: Thu Mar 27, 2008 12:09 pm     Reply with quote
Moreover, when the ext interrupt is triggered, the code will goes out the
loop and then execute
starter = false;
And after...
What's happening?
Matro
ZeroF877A
PostPosted: Thu Mar 27, 2008 12:21 pm     Reply with quote
After the loop ends when starter = true, the "starter = false" is written so the moment I return to that specific area, it won't just go ahead again and execute the rest of the program.
Also, Matro. That endless loop only happens IF something else happens first.
Check the {}'s in the code and see for yourself.
Anyways, the problem seems to have miraculously solved by itself...
Matro
PostPosted: Thu Mar 27, 2008 12:27 pm     Reply with quote
The question about the endless loop is : Why write it like you did it when you can just write :
since nothing happens in the loop.
Check that NOLVP is present among your #FUSES directives.
If you want more help, please post a complete "compilable" code with fuses.
Matro.
PostPosted: Thu Mar 27, 2008 9:37 pm     Reply with quote
And may I add to that to please use a correct indentation. Now at least three seasoned programmers (Me, Ttelmah and Matro) overlooked your problem because of bad formatting.
Douglas Kennedy
PostPosted: Fri Mar 28, 2008 1:24 am     Reply with quote
I'm reluctant to jump in on this since the person with the issue seems to believe in their code more than the reality that their code didn't work.
Coding an RTC for most coders is a basic task that is accomplished without
the issues presented by ZeroF877A's code.
The enable_interrupts (GLOBAL) is missing in the snippet of code given as well as the initialization of the variable starter.
Now ZeroF877A's faith in his/her code has according to ZeroF877A resulted in a miracle.... it was self repairing. Wish we all could be as blessed.
ZeroF877A
PostPosted: Fri Mar 28, 2008 7:00 am     Reply with quote
If you see your code working as you designed it to work on a physical MCU (except for the interrupt part), you're bound to think it's functional, no? I've been working with these MCU for nearly 10 months now (used to work in assembly), so it's not like I don't know what I'm doing.
Anyway, I might add that I had to replace the PIC with a new one, and change the wiring in my board for it to work. The code works perfectly fine, and if anyone is still reluctant about it, I can upload a video to prove it.
PostPosted: Fri Mar 28, 2008 8:54 am     Reply with quote
Unfortunately, it seems that Douglas was right. We can have looked for a solution during hours since your hardware was bad... That is the first thing to check if you never successfully run a software on it. :-/
Personnaly I work with µC and program in embedded C and ASM for years. And I always produce code with a proper indentation and a lot of comments. It makes my job easier and the one of my colleagues too. ;-)
See you!
Matro
