Problem with 1-Wire library
Inkwaterman
PostPosted: Fri Mar 28, 2008 2:36 am     Reply with quote
Hi !
I use the "1-Wire" library done by j.d.sandoz for communicated with DS2760 and I have the following problem:
If I setup the internal clock to 8 Mhz the library works fine.
For my project I have to put the clock to 1 Mhz, but with this setup the library doesn't work....
If you look the code you'll find that there are only absolute delays (dely_ms() )..
Why the library doesn't work at 1 mhz ?
thanks !
defines: ONE_WIRE_PIN
Pin Per la comunicazione one-wire con il PIC
#define ONE_WIRE_PIN PIN_J5
void onewire_disable_interrupts(int disable) {
   if (disable)
     disable_interrupts(GLOBAL);
short int onewire_init_with_error_check() {
   onewire_disable_interrupts(TRUE);
   output_low(ONE_WIRE_PIN);
   delay_us( 500 ); // pull 1-wire low for reset pulse
   output_float(ONE_WIRE_PIN); // float 1-wire high
   delay_us( 5 );   // allow pin to stabilize
   if (!input(ONE_WIRE_PIN)) {
      onewire_disable_interrupts(FALSE);
      return ( FALSE ); // error (1-wire leads shorted)
   delay_us( 80 ); // wait for presence pulse, allowing for device variation
   if (input(ONE_WIRE_PIN)) {
      return ( FALSE ); // error (no 1-wire devices present)
   delay_us( 420 ); // wait-out remaining initialisation window.
   //printf(debug_putc,"<>ok >onewire_init\n\r");
   return ( TRUE ); // device(s) present and initialised.
void onewire_init() { // OK if just using a single permanently connected device
void onewire_sendbyte(int data) {
   int count;
   //static int debugS;
   //printf(debug_putc,"0x%x >onewire_sendbyte(%u)\n\r",data,debugS++);
   for (count=0; count<8; ++count) {
      delay_us( 2 ); // pull 1-wire low to initiate write time-slot.
      output_bit(ONE_WIRE_PIN, shift_right(&data,1,0)); // set output bit on 1-wire
      delay_us( 60 ); // wait until end of write slot.
      output_float(ONE_WIRE_PIN); // set 1-wire high again,
      delay_us( 2 ); // for more than 1us minimum.
int onewire_readbyte() {
   int count, data;
   //static int debugR;
      delay_us( 2 ); // pull 1-wire low to initiate read time-slot.
      output_float(ONE_WIRE_PIN); // now let 1-wire float high,
      delay_us( 8 ); // let device state stabilise,
      shift_right(&data,1,input(ONE_WIRE_PIN)); // and load result.
      delay_us( 120 ); // wait until end of read slot.
   //printf(debug_putc,"0x%x >onewire_readbyte(%u)\n\r",data,debugR++);
   return( data );
int onewire_crc(int oldcrc, int newbyte) {
   // see http://pdfserv.maxim-ic.com/arpdf/AppNotes/app27.pdf
   int shift_reg, data_bit, sr_lsb, fb_bit, j;
   shift_reg=oldcrc;
   for(j=0; j<8; j++) {   // for each bit
      data_bit = (newbyte >> j) & 0x01;
      sr_lsb = shift_reg & 0x01;
      fb_bit = (data_bit ^ sr_lsb) & 0x01;
      shift_reg = shift_reg >> 1;
      if (fb_bit)
         shift_reg = shift_reg ^ 0x8c;
   return(shift_reg);
Douglas Kennedy
PostPosted: Fri Mar 28, 2008 7:52 am     Reply with quote
Providing the #FUSES statement and the #USE delay
are almost always necessary when asking others to look at your code.
Since you assert your code works at 8mhz then it will be a fools errand for others to look at it. The error will probably be in the fuses or some other undisclosed snippet of your code.
nemena12
PostPosted: Mon Sep 07, 2009 3:39 am     Reply with quote
A good choice is to choose a XTAL that provides 1us of instruction cycle or minus.
For PIC's the instruction cycle = 1/ (fXTAL/4).
So in your case 4 mhz is required....
