EL
Problem with Controller area network (CAN) |
Posted: Thu Mar 27, 2008 12:02 pm |
Hi
I use from PIC16F876 MCP2515.
Bus speed: 125kb/s
I can not send data to card CAN at PC "Advantech PCL -841"
My hardware this:
16F876 MCP2515 PCA82C250
---SI---->S0-----
---S0---->SI----- ----->TX -RX-------->CANH
---SCK-->SCK-- ------>RX-TX-------->CANL
---C0---->CS----
Software this:
"can - mcp 2515x.h" and
"can - mcp 251x.c" :
//// can-mcp2510.c ////
//// CAN Library routines for Microchip's MCP2510 (and compatable) ////
//// CAN IO expanders. ////
//// PRZEROBIONE przez ERYK ////
#include <can-mcp251x_eryk.h>
//IO pins connected to MCP2510
#ifndef EXT_CAN_CS
#define EXT_CAN_CS PIN_C0
#define EXT_CAN_SI PIN_C5
#define EXT_CAN_SO PIN_C4
#define EXT_CAN_SCK PIN_C3
// #define EXT_CAN_RESET PIN_B5 //reset
#if CAN_DO_DEBUG
#define can_debug printf
#else
#define can_debug
#define READ 0x03
#define WRITE 0x02
#define READSTATUS 0xA0
// can_init()
// Inicjalizacja MCP2515.Ustawiam tak filtry i maski by wszystkie ID's mogly byc odebrane.
// Konfiguruje bufory tak by odbieraly wszystkie wazne wiadomosci...
void can_init(void) {
struct struct_RXB0CTRL b_rxb0ctrl;
mcp2510_init();
can_set_mode(CAN_OP_CONFIG); //tryb konfiguracyjny
can_set_baud(); //predkosci
b_rxb0ctrl=0; //RXB0CTRL=0
b_rxb0ctrl.rxm=CAN_RX_VALID; //tryb 00 otrzymuj wszystkie wazne wiadomoĊci
b_rxb0ctrl.bukt=CAN_USE_RX_DOUBLE_BUFFER; //gdy RXB0 pelny to przeslij do RXB1
mcp2510_write(RXB0CTRL, (int)b_rxb0ctrl); //przeslij do RXB0CTRL
mcp2510_write(RXB1CTRL, (int)b_rxb0ctrl); //przeslij do RXB1CTRL
can_set_id(RX0MASK, CAN_MASK_ACCEPT_ALL, CAN_USE_EXTENDED_ID); //maska 0 (RX bufor 0) //adres=0x23h(RXM0EIDL),id=0,uzywam rozszerzonej ramki
can_set_id(RX0FILTER0, 0, CAN_USE_EXTENDED_ID); //filtr 0 w masce 0 (RX bufor 0) //adres=0x03h(RXF0EIDL),id=0,uzywam rozszerzonej ramki
can_set_id(RX0FILTER1, 0, CAN_USE_EXTENDED_ID); //filtr 1 w masce 0 (RX bufor 0) //adres=0x07h(RXF1EIDL),id=0,uzywam rozszerzonej ramki
can_set_id(RX1MASK, CAN_MASK_ACCEPT_ALL, CAN_USE_EXTENDED_ID); //maska 1 (RX bufor 1) //adres=0x27h(RXM1EIDL),id=0,uzywam rozszerzonej ramki
can_set_id(RX1FILTER2, 0, CAN_USE_EXTENDED_ID); //filtr 0 w masce 1 (RX bufor 1) //adres=0x0bh(RXF2EIDL),id=0,uzywam rozszerzonej ramki
can_set_id(RX1FILTER3, 0, CAN_USE_EXTENDED_ID); //filtr 1 w masce 1 (RX bufor 1) //adres=0x13h(RXF3EIDL),id=0,uzywam rozszerzonej ramki
can_set_id(RX1FILTER4, 0, CAN_USE_EXTENDED_ID); //filtr 2 w masce 1 (RX bufor 1) //adres=0x17h(RXF4EIDL),id=0,uzywam rozszerzonej ramki
can_set_id(RX1FILTER5, 0, CAN_USE_EXTENDED_ID); //filtr 3 w masce 1 (RX bufor 1) //adres=0x1bh(RXF5EIDL),id=0,uzywam rozszerzonej ramki
can_set_mode(CAN_OP_NORMAL); //tryb normalny
// can_set_baud()
// Konfiguracja Baud Rate(predkosci transmisji)
// SyncSeg=1TQ
// PropSeg=1TQ
// PhSeg1=3TQ
// PhSeg2=3TQ
// BIT TIME=8TQ=8us
// Predkosc=1/8TQ=1/8us=125kb/s
void can_set_baud(void) {
struct struct_CNF1 new_CNF1;
struct struct_CNF2 new_CNF2;
struct struct_CNF3 new_CNF3;
new_CNF1.brp=CAN_BRG_PRESCALAR; //BRP=7 czyi TQ=2x(7+1)/16MHz=1us
new_CNF1.sjw=CAN_BRG_SYNCH_JUMP_WIDTH; //SJW=0 czyli 1TQ
new_CNF2.prseg=CAN_BRG_PROPAGATION_TIME; //PRSEG=0 czyli 1TQ
new_CNF2.phseg1=CAN_BRG_PHASE_SEGMENT_1; //PHSEG1=2 czyli 3TQ
new_CNF2.sam=CAN_BRG_SAM; //SAM=0
new_CNF2.btlmode=CAN_BRG_SEG_2_PHASE_TS; //BTLMODE=1
new_CNF3.phseg2=CAN_BRG_PHASE_SEGMENT_2; //PHSEG2=2 czyli 3TQ
new_CNF3.wakfil=CAN_BRG_WAKE_FILTER; //WAKFIL=1
mcp2510_write(CNF1, (int)new_CNF1);
mcp2510_write(CNF2, (int)new_CNF2);
mcp2510_write(CNF3, (int)new_CNF3);
void can_set_mode(CAN_OP_MODE mode) //funkcja ustawiajaca tryb w normalny
struct struct_CANCTRL old_CANCTRL;
old_CANCTRL=mcp2510_read(CANCTRL);
old_CANCTRL.reqop=mode;
mcp2510_write(CANCTRL, (int)old_CANCTRL);
do {
} while (old_CANCTRL.reqop != mode);
// can_set_id()
// Konfiguracja rejestrow xxxxEIDL, xxxxEIDH, xxxxSIDL i xxxxSIDH
// Konfiguruje zdefiniowane bufory by uzywaly odpowiednich ID
// Parametry:
// addr - wskaznik do pierwszego bajtu z ID rejestru, zaczynajac od xxxxeidl.
// id - ustawia ID w buforze
// ext - TRUE gdy uzywam rozszerzonego ID, FALSE gdy nie.
void can_set_id(int addr, int32 id, int1 ext) {
int converted_id[4];
int *ptr;
ptr=&converted_id[3]; //3=eidl, 2=eidh, 1=sidl, 0=sidh
if (ext) { //extended
//eidl
*ptr=make8(id,0); //0:7
//eidh
ptr--;
*ptr=make8(id,1); //8:15
//sidl
ptr--;
*ptr=make8(id,2) & 0x03; //16:17
*ptr|=(make8(id,2) << 3) & 0xE0; //18:20
*ptr|=0x08;
//sidh
ptr--;
*ptr=((make8(id,2) >> 5) & 0x07 ); //21:23
*ptr|=((make8(id,3) << 3) & 0xF8);//24:28
else { //standard
//eidl
*ptr=0;
//eidh
ptr--;
*ptr=0;
//sidl
ptr--;
*ptr=(make8(id,0) << 5) & 0xE0;
//sidh
ptr--;
*ptr=(make8(id,0) >> 3) & 0x1F;
*ptr|=(make8(id,1) << 5) & 0xE0;
//0=eidl, 1=eidh, 2=sidl, 3=sidh
mcp2510_write(addr--, converted_id[3]);
mcp2510_write(addr--, converted_id[2]);
mcp2510_write(addr--, converted_id[1]);
mcp2510_write(addr, converted_id[0]);
// can_get_id()
// Zwraca ID z odpowiedniego bufora(odwrotnosc funkcji can_set_id())
// Uzywam tej funkcji gdy odbieram wiadomosc, widze wiadomosc i jaki ma ID.
// Parametry:
// Zwraca:
// ID z buforu
int32 can_get_id(int addr, int1 ext) {
int32 ret;
int * ptr;
converted_id[3]=mcp2510_read(addr--);
converted_id[2]=mcp2510_read(addr--);
converted_id[1]=mcp2510_read(addr--);
converted_id[0]=mcp2510_read(addr);
ret=0;
if (ext) {
ret=*ptr; //eidl
ptr--; //eidh
ret|=((int32)*ptr << 8);
ptr--; //sidl
ret|=((int32)*ptr & 0x03) << 16;
ret|=((int32)*ptr & 0xE0) << 13;
ptr--; //sidh
ret|=((int32)*ptr << 21);
else {
ptr-=2; //sidl
ret=((int32)*ptr & 0xE0) >> 5;
ptr--; //sidh
ret|=((int32)*ptr << 3);
return(ret);
// can_putd()
// Funkcja wysylania danych na magistrali CAN
// Parametry:
// id - identyfikator
// data - wskaznik danych
// len - dlugosc danych wysylanych
// priority - Priorytet wiadomosci(od 0-najnizszy do 3-najwyzszy)
// rtr - TRUE ustawia RTR (prosba/zadanie) bit w ID, FALSE nie.
// Zwraca:
// Gdy SUKCES TRUE
// GDy PORAZKA FALSE
int1 can_putd(int32 id, int * data, int len, int priority, int1 ext, int1 rtr) {
int i;
int port;
int TXRXBaD0; //pole danych (8 bitow)
int TXBaCTRL; //rejestr konfiguracyjny
int TXRXBaEIDL; //rejestry identyfikatorow
int TXBaDLC; //rejestr dlugosci danych (RTR + 4 bity DLC)
struct txbNctrl_struct b_TXBaCTRL;
struct rxbNdlc_struct b_TXBaDLC;
struct txbNctrl_struct b_TXB0CTRL, b_TXB1CTRL, b_TXB2CTRL;
b_TXB0CTRL=mcp2510_read(TXB0CTRL); //odczyt z TXB0CTRL i zapis do b_TXB0CTRL
b_TXB1CTRL=mcp2510_read(TXB1CTRL);
b_TXB2CTRL=mcp2510_read(TXB2CTRL);
// znajduje wolny nadajnik
// mapowanie dostepnych bankow adresow
if (!b_TXB0CTRL.txreq) {
TXRXBaD0=TXB0D0; //dane
TXBaCTRL=TXB0CTRL; //bity kontrolne
TXRXBaEIDL=TXB0EIDL; //identyfikator
TXBaDLC=TXB0DLC; //dl.danych
port=0; //bufor0
else if (!b_TXB1CTRL.txreq) {
TXRXBaD0=TXB1D0;
TXBaCTRL=TXB1CTRL;
TXRXBaEIDL=TXB1EIDL;
TXBaDLC=TXB1DLC;
port=1;
else if (!b_TXB2CTRL.txreq) {
TXRXBaD0=TXB2D0;
TXBaCTRL=TXB2CTRL;
TXRXBaEIDL=TXB2EIDL;
TXBaDLC=TXB2DLC;
port=2;
else {
#if CAN_DO_DEBUG
can_debug("\r\nCAN_PUTD() FAIL: NO OPEN TX BUFFERS\r\n");
return(0);
//***PRIORYTET***
b_TXBaCTRL=mcp2510_read(TXBaCTRL);
b_TXBaCTRL.txpri=priority;
mcp2510_write(TXBaCTRL, (int)b_TXBaCTRL);
//***ustawiam maski TX***
can_set_id(TXRXBaEIDL, id, ext);
//**ustawiam dlugosc danych***
b_TXBaDLC=len;
b_TXBaDLC.rtr=rtr;
mcp2510_write(TXBaDLC, (int)b_TXBaDLC);
//***zapis do bufora***
for (i=TXRXBaD0; i<(TXRXBaD0 + len); i++) {
mcp2510_write(i,*data);
data++;
//***ENABLE transmisja***
b_TXBaCTRL.txreq=1;
#if CAN_DO_DEBUG
can_debug("\r\nCAN_PUTD(): BUFF=%U ID=%LX LEN=%U PRI=%U EXT=%U RTR=%U\r\n", port, id, len, priority, ext, rtr);
if ((len)&&(!rtr)) {
data-=len;
can_debug(" DATA = ");
for (i=0;i<len;i++) {
can_debug("%X ",*data);
data++;
can_debug("\r\n");
return(1);
// can_getd()
// Odczyt danych z biufora odbioru (jezeli sa tam dane)
// Parametry:
// id - ID
// len - dlugosc(liczba) danych
// stat - struktura z informacjami (ktory bufor odbiera, ext czy standard, itp)
// Zwraca:
// Funkcja wywoluje TRUE jesli cos jest w buforze odbioru,FALSE gdy nie
int1 can_getd(int32 & id, int * data, int & len, struct rx_stat & stat)
int i;
struct struct_RXB0CTRL b_RXB0CTRL;
struct struct_RXB1CTRL b_RXB1CTRL;
struct struct_EFLG b_EFLG;
int RXBaDLC;
struct rxbNdlc_struct b_RXBaDLC;
int TXRXBaSIDL;
struct struct_TXRXBaSIDL b_TXRXBaSIDL;
int RXBaD0;
struct struct_CANINTF b_CANINTF;
b_CANINTF=mcp2510_read(CANINTF); //odczyt rejestru CANINTF(
b_RXB0CTRL=mcp2510_read(RXB0CTRL); //odczyt rejestrow kontrolnych poszczegolnych buforow
b_RXB1CTRL=mcp2510_read(RXB1CTRL);
b_EFLG=mcp2510_read(EFLG); //odczyt flagi EFLG(flaga bledu)
if (b_CANINTF.rx0if) { //jezeli jest wiadomosc w buforze 0
stat.buffer=0;
stat.err_ovfl=b_EFLG.rx0ovr; //informuje czy bufor 0 jest pelny
b_EFLG.rx0ovr=0; //nie jest pelny
mcp2510_write(EFLG, (int)b_EFLG); //przeslij do EFLG
if (b_RXB0CTRL.bukt) { //jezeli BUKT=1, czyli gdy RXBO jest pelny to dane sa przesylane do RXB1
stat.filthit=b_RXB0CTRL.filhit0; //filtry
RXBaDLC=RXB0DLC; //dlugosc pola danych
TXRXBaSIDL=RXB0SIDL; //maskowanie
RXBaD0=RXB0D0; //dane
else if (b_CANINTF.rx1if)
stat.buffer=1;
stat.err_ovfl=b_EFLG.rx1ovr;
b_EFLG.rx1ovr=0;
stat.filthit=b_RXB1CTRL.filhit0;
RXBaDLC=RXB1DLC;
TXRXBaSIDL=RXB1SIDL;
RXBaD0=RXB1D0;
else {
#if CAN_DO_DEBUG
can_debug("\r\nFAIL ON CAN_GETD(): NO MESSAGE IN BUFFER\r\n");
return (0);
//***odczyt dlugosci pola danych***
b_RXBaDLC=mcp2510_read(RXBaDLC); //odczyt RXBaDLC i wpisanie do zmiennej b_RXBaDLC
len = b_RXBaDLC.dlc; //len (dlugosc danych)
stat.rtr=b_RXBaDLC.rtr; //rtr (ramka danych czy ramka zdalna)
//***extended czy standard?***
b_TXRXBaSIDL=mcp2510_read(TXRXBaSIDL);
stat.ext=b_TXRXBaSIDL.ext;
id=can_get_id(TXRXBaSIDL + 2,stat.ext);
//***odczyt danych***
for ( i = RXBaD0; i < (RXBaD0 + len); i++ ) {
*data=mcp2510_read(i);
data++;
stat.inv=b_CANINTF.merrf;
if (b_CANINTF.merrf) { //gdy MERRF=1 to nastapil blad (oczekiwanie na przerwanie)
b_CANINTF.merrf=0; //zerowanie
if (stat.buffer) { //jezeli bufor 1
b_CANINTF.rx1if=0; //nie oczekuje na przerwanie od przepelnienia bufora 1
else {
b_CANINTF.rx0if=0; //nie oczekuje na przerwanie od przepelnienia bufora 0
mcp2510_write(CANINTF, (int)b_CANINTF);
#if CAN_DO_DEBUG
can_debug("\r\nCAN_GETD(): BUFF=%U ID=%LX LEN=%U OVF=%U ", stat.buffer, id, len, stat.err_ovfl);
can_debug("FILT=%U RTR=%U EXT=%U INV=%U", stat.filthit, stat.rtr, stat.ext, stat.inv);
if ((len)&&(!stat.rtr)) {
data-=len;
can_debug("\r\n DATA = ");
data++;
can_debug("\r\n");
return(1);
// can_kbhit()
// Zwraca TRUE jezeli w buforze odbioru sa jakies dane
int1 can_kbhit(void) {
if (b_CANINTF.rx0if || b_CANINTF.rx1if)
{return(1);}
return(0);
// can_tbe()
// Zwraca TRUE jesli bufory transmisji sa puste i gotowe do transmitowania danych
int1 can_tbe(void) {
if (!b_TXB0CTRL.txreq || !b_TXB1CTRL.txreq || !b_TXB2CTRL.txreq)
{return(1);}
return(0);
// can_abort()
// Odrzuca wszystkie oczekujace transmisje
void can_abort(void) {
struct struct_CANCTRL b_CANCTRL;
b_CANCTRL=mcp2510_read(CANCTRL);
b_CANCTRL.abat=1; //ABAT=1,odrzucenie transmisji
mcp2510_write(CANCTRL, (int)b_CANCTRL);
delay_ms(5);
b_CANCTRL.abat=0;
// SPI CODE
//data clocked in on rising edge
//data driven out on falling edge
int mcp2510_read(int address)
int command[2];
int i;
int data;
command[1]=0x03;
command[0]=address;
output_low(EXT_CAN_CS);
for (i=0;i<16;i++)
output_bit(EXT_CAN_SI, shift_left(&command[0],2,0));
output_high(EXT_CAN_SCK);
output_low(EXT_CAN_SCK);
for (i=0;i<8;i++)
shift_left(&data,1,input(EXT_CAN_SO));
output_high(EXT_CAN_CS);
return(data);
////////////////kod ERYK//////////////////////
int data;
output_low(EXT_CAN_CS); //zalaczenie MCP2515
spi_write(READ); //wyslanie instrukcji odczytu
spi_write(address); //odczyt z rejestru
data = spi_read(0x00); //odczyt z rejestru do data
output_high(EXT_CAN_CS); //SPI koniec
return(data);
////////////////KONIEC kod ERYK//////////////////////
int mcp2510_status(void) {
int command;
int data;
int i;
command=0xA0;
for (i=0;i<8;i++) {
output_bit(EXT_CAN_SI, shift_left(&command,1,0));
for (i=0;i<8;i++) {
for (i=0;i<8;i++) {
return(data);
int data;
spi_write(READSTATUS); //wyslanie instrukcji statusu
output_high(EXT_CAN_CS); //wylaczenie MCP2515
return(data);
void mcp2510_write(int address, int data) {
int command[3];
int i;
command[2]=0x02;
command[1]=address;
command[0]=data;
for (i=0;i<24;i++) {
output_bit(EXT_CAN_SI, shift_left(&command[0],3,0));
spi_write(WRITE); //wyslanie instrukcji zapisu
spi_write(address); //adres
spi_write(data); //dana
void mcp2510_command(int command) {
int i;
for (i=0;i<8;i++) {
spi_write(command); //wyslanie komendy
void mcp2510_init(void)
mcp2510_command(0xC0); //reset
delay_ms(5);
///////////////KONIEC/////////////////////////////////
main:
#include <16F876.h>
#include <F876.h>
#define CAN_DO_DEBUG TRUE
#include <can-mcp251x.c>
struct rx_stat rxstat;
int32 rx_id;
int buffer[8];
int rx_len;
int data=0x05;
int i;
trisc_0=0;
trisc_1=0;
trisc_2=0;
trisc_3=0;
trisc_4=0;
trisc_5=1;
trisc_6=0;
trisc_7=0;
//Tryb MASTER,czestowliowsc 1MHz
//SSPCON=00100000(SSPEN=1),SSPSTAT=1000000(SMP=1,CKP=0,CKE=0)
setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_CLK_DIV_4 | SPI_SAMPLE_AT_END);
for(i=0;i<8;i++) {
buffer[i]=0;
can_init();
can_putd(0x202, &data, 1,1,1,0); //put data on transmit buffer
What do I do bad?
I thank for help |
Posted: Thu Mar 27, 2008 3:42 pm |
Your question is really how to convert the CCS MCP2515 driver from
using software SPI to using hardware SPI.
Quote: |
trisc_0=0;
trisc_1=0;
trisc_2=0;
trisc_3=0;
trisc_4=0;
trisc_5=1;
trisc_6=0;
trisc_7=0;
CCS handles setting the TRIS for you. You don't have to do this.
If you use "standard i/o" mode (the default mode of the compiler)
and if you use CCS i/o functions (such as output_low(), etc.), then
the compiler will automatically set the correct TRIS for you.
Also, if you use CCS built-in functions such as setup_spi(), the compiler
will automatically setup the correct TRIS for the SDO, SDI, and SCK pins.
Delete those lines above.
Quote: |
setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_CLK_DIV_4 | SPI_SAMPLE_AT_END); |
This is wrong. You're setting the wrong SPI mode. Here is a list of
SPI mode definitions. You're setting mode 1, with sample at end.
#define SPI_MODE_0_0 (SPI_L_TO_H | SPI_XMIT_L_TO_H)
#define SPI_MODE_0_1 (SPI_L_TO_H)
#define SPI_MODE_1_0 (SPI_H_TO_L)
#define SPI_MODE_1_1 (SPI_H_TO_L | SPI_XMIT_L_TO_H)
Look on page 63 of the MCP2515 data sheet:
http://ww1.microchip.com/downloads/en/DeviceDoc/21801e.pdf
It tells you the correct SPI mode to use:
Quote: | 12.0 SPI INTERFACE
12.1 Overview
The MCP2515 is designed to interface directly with the
Serial Peripheral Interface (SPI) port available on many
microcontrollers and supports Mode 0,0 and Mode 1,1. |
Add those #define statements to your program and then change the
setup_spi() statement to this:
Code: | setup_spi(SPI_MASTER | SPI_MODE_0_0 | SPI_CLK_DIV_4); |
Also make sure you connect a 120 ohm termination resistor across the
CANH and CANL lines next to the PCA82C250 on your PIC board.
You need a termination resistor on your board and also on the PCL-841.
The Advantech PCL-841 board has terminator resistors on it for each
CAN bus connector. But you must install a jumper on the board (JP9 or
JP10) to enable the resistors. Make sure you do that. |
EL
Posted: Fri Mar 28, 2008 3:50 am |
I thank PCM programmer
I will check this all really on Monday because I will be then dust card CAN.
You assured me in conviction from these TRIS'es.thanks
I will improve also settings SPI and resistor (120 ohm) I have on single board only I forgot about inserting jumper.
Salute:) |
