sohailkhanonline
help in LRC checksum string |
Posted: Thu Mar 27, 2008 10:31 pm |
HI,
i have a string
"010909000AFFFFFFFFFFFF"
i want to calculate checksum such that
01 (XOR) 09 (XOR) 09 (XOR) 00 (XOR) 0A (XOR) FF (XOR) FF (XOR) FF (XOR) FF (XOR) FF (XOR) FF
and
put it in the end of the string
the result in this case is
"0B"
so that the resulting string becomes
"010909000AFFFFFFFFFFFF0B"
I have tried the following code but failed
Code: | BYTE string[24];
BYTE getLRC(BYTE *pbdata,int icount)
BYTE chlrc = 0;
while(icount > 0)
chlrc ^= *pbdata;
pbdata=pbdata+2;
icount--;
return chlrc;
strcpy(string,"010909000AFFFFFFFFFFFF00");
string[22]=getLRC(&string[0],11);
string[23]=getLRC(&string[1],11);
for(i=0;i<24;i++)
putc(string[i]);
i get the data
010909000AFFFFFFFFFFFF which is missing the last two characters
Please help me! _________________ sohail khan |
Posted: Fri Mar 28, 2008 1:32 am |
Quote: | BYTE string[24];
strcpy(string,"010909000AFFFFFFFFFFFF00"); |
Your array can only hold 24 bytes. Your string is 24 bytes.
But a string always has a terminator byte at the end, which is 0x00.
You need to increase your array size to 25. |
Posted: Fri Mar 28, 2008 2:16 am |
in this case array is terminated by ETX
but i didn't mentioned it
for the sake of ease
this is not complete code its the part which is not working |
Posted: Fri Mar 28, 2008 3:21 am |
The ETX, doesn't change the point that PCMprogrammer is making. You start with a 24 character string. A 24 character string _requires_ 25 characters of storage. As soon as you use 'strcpy' to move the constant string into the storage area, the _next_ location in memory, _will_ be destroyed.
If working with string library functions, you _must_ allow for the terminator character.
Wayne_
Posted: Fri Mar 28, 2008 3:29 am |
As PCM said you need to define your string as
BYTE string[25];
Although you are iterating through the 24 locations and using putc the function strcpy in main requires an array of 25 bytes not 24!
The problem with your code is that getLRC returns a numerical value and NOT the ASCII code you require so the following
BYTE chlrc = 0;
while(icount > 0)
chlrc ^= *pbdata;
pbdata=pbdata+2;
icount--;
return chlrc;
returns the value 0 which is a string termination character and not the char '0' which you need to put at position 22. So when you put it at position 22 the putc routine thinks pos 22 is the end of the string!
Now there is a big problem with the way you are doing it because you will return an 8 bit number for the even indexes and another 8 bit number for the odd indexes. These when converted to ascii will occupy 4 positions e.g. 0x000B.
I would to the following
First you need to convert each pair of chars to a value, there are many ways to do this but try:-
BYTE getLRC(BYTE *pbdata,int icount) {
BYTE chlrc = 0;
char hex[5] = "0x00";
while(icount-- > 0) {
hex[2] = *pbdata++;
hex[3] = *pbdata++;
chlrc ^= atoi(hex); // Convert the hex string to a value
return chlrc;
the second problem is in main
for(i=0;i<24;i++)
putc(string[i]);
Change to
int8 crc;
char *pos;
crc = getLRC(string[0], 11);
pos = string[22];
sprintf(pos, "%X", crc);
string[24] = 0;
printf("%s", string);
//for(i=0;i<24;i++)
// putc(string[i]);
I think that is it but I have to go now so good luck.
Matro Guest
Posted: Fri Mar 28, 2008 3:44 am |
- You need to convert your hexadecimal-coded string to integer
- You need to have a sufficient array length to store the data, the checksum and the termination char.
- When doing your putc() and if you want to see the result, you have to send more than ust the 24 bytes of data...
BYTE string[27];
BYTE chlrc = 0;
while(icount > 0)
if(*pbdata <= '9')
chlrc ^= (*pbdata) - '0';
chlrc ^= (*pbdata) - 'A' + 0xA;
pbdata=pbdata+2;
icount--;
if(chlrc <= '9')
return chlrc + '0';
return chlrc - 0xA + 'A';
for(i=0;i<26;i++)
putc(string[i]);
Your way of coding is not very proper but I try to stay close to that and this could should work.
Matro |
