hi,
can anyone help me to do a program using strcmp?
below is my coding that already succes.
but when i burned to pic,the program didn't work as i want..
unsigned short i[68];
//char input[77];
int ptr;
char in[]="$";
Usart_Init(4800);
// in = "$";
do {
if (Usart_Data_Ready()) // If data is received
i[68] = Usart_Read(); // Read the received data
ptr = strcmp(i, in);
if (ptr == 0)
{ Usart_Write('Y'); } // Send data via USART
{ Usart_Write ('N');}
} while (1);
Posted: Fri Mar 28, 2008 1:26 am
That's not CCS code. It's mikroC code. You should ask your question on
their forum:
http://www.mikroe.com/forum/
