ist worker Guest
garbage input with rs232 bluetooth but perfect output |
Posted: Thu Mar 27, 2008 9:19 am |
Compiler version: 3.245
Pic version: 18F8722
Here a short description of a problem that has really been frustrating me, and its doubly frustrating since I fixed it in the past, but don't remember how now. Also ive searched the forum thoroughly for insight into this problem and havent found an answer, but in case i am rehashing a common topic, i do apologize.
I am able to communicate with the pic using a bluetooth connection, but input is getting garbled, while communication originating from the pic comes through clearly. I tested this by just echoing input back out, as well as following that by putc'ing another character. So when i send the pic something i get garbage output, sometimes random, most times "<0>" , and that is followed by the putc character.
I know hardware is not an issue here, since the same pic has been loaded with working firmware and tested.
Im going to post my code, and i really appreciate if someone could help me shed some light on this. My own intuition tells me it has something to do with fuses, because i know little to nothing about what they do. Thanks!!
//model of pic
#include <18F8722.H>
//#DEVICE ADC=10
#fuses NOLVP // Low Voltage ICSP Disabled
#fuses H4
#fuses NOWRT
#fuses NOPUT // Power Up Timer
//#fuses NOBROWNOUT // Brown Out Reset enabled
#fuses NOWDT // no watch dog timer
//#fuses NOPROTECT // No Code Protect
//#fuses NODEBUG // No Background Debugger
//#fuses MCLR
//clock speed set here
#use delay(clock=24000000)
//setup of rs232
#use rs232(STREAM=serial,BAUD=115200,XMIT=PIN_C6,RCV=PIN_C7,PARITY=N,BITS=8)
void readPacket();
void init();
init();
//read data available interrupt
#int_rda
void readPacket()
char inchar;
// While there are incoming bytes waiting to be read...
while (kbhit())
// Get an incoming character
inchar = getc();
putc(inchar);
putc('a');
void init()
enable_interrupts(INT_RDA);
SET_TRIS_A( 0xff );
SET_TRIS_B( 0xff );
SET_TRIS_C( 0xbf );
SET_TRIS_D( 0xff );
SET_TRIS_E( 0xff );
printf("Initilizing\n\r");
Wayne_
Posted: Thu Mar 27, 2008 9:45 am |
Most likely something to do with the pic going to sleep after init() in main.
Try putting
while(true) {
after init().
This will prevent the pic going to sleep.
No gaurantees with this though! |
Posted: Thu Mar 27, 2008 9:49 am |
thanks wayne, actually i did have a while loop in there just looping forever with nothing in it, i didnt think it was necessary, but with it in the same problem still applies. |
Wayne_
Posted: Thu Mar 27, 2008 10:05 am |
because you are not using fast_io those set_tris statements mean nothing.
They should be done before the enable ints anyway.
Just remove them unless you plan on using fast_io! |
ist worker Guest
Posted: Thu Mar 27, 2008 10:10 am |
thanks again, i forgot to put my name in my last post btw.
I put those set_tris statements in to see if it would remedy my problem, but with those statements removed, i still have the same problem. |
ist worker Guest
Posted: Thu Mar 27, 2008 11:58 am |
Wow ok, the problem has been solved, thank goodness.
I was powering the PIC circuit board through the ICD-U40 thingy plugged into the usb port rather than through the battery pack. The EE i work with pointed out that it may not be enough power to run bluetooth, and he was right! Using the correct power source solved the problem. |
